Question about La Crosse Radio Controlled Atomic Clock
Advance not working for daylight saving time - La Crosse Radio Controlled Atomic Clock
How do i change the date to the dvr
To adjust the date and time, press the Menu button on the Remote Control, select
ADVANCED and then select DATE AND TIME
SET BY: Select MANUAL to adjust the data and time by yourself, or NETWORK to
synchronize the date and time with a time server. If you select NETWORK, then the option
of SERVER appears. Use the on-screen keypad to enter the IP address of the time server.
􀂄 DAY LIGHT SAVING: Automatically adjust the GV-Compact DVR V2 for daylight saving
time. Enter the Start and End time of daylight saving.
May 12, 2011 | Geovision GV-LX4C2V Mobile Security DVR...
I used your instructions to "reset" clock. I did but I have same problem with time. The PROBLEM is how to advance time to adjust to "daylight savings time"? Roy
The phone should automatically adjust to daylight savings time when the phone is powered off then back on again. As the phone reboots, it reconnects to the cell carrier's servers and requests the local time. The server's should have already accounted for daylight savings time, therefore, giving the correct time to your phone.
Mar 13, 2011 | Cell Phones
HELLO MY CLOCK DID NOT DO AUTO DAYLIGHT TIME HOW DO I FIX THE TIME TO ADJUST TO ONE HOUR A HEAD THANK YOU INGER WELCH
All you need to do to advance your clock an hour for daylight savings time, is hold down your clock button without letting it go. Then press your hour button once and you should be all set.
Most clocks that are older than when they changed the date of daylight savings time will either not change it for you on the right day anymore. Or they don't have that feature in it.
If yours does have an automatic daylight savings feature...you may find it helpful to take it off "automatic" and just change it manually from now on. That's what I do with my VCR. It has an automatic daylight savings time feature, but it's useless now that they have changed the date when we set our clocks for DST.
Some manufacturers will give you instructions on how to change the feature settings so your product will again work correctly for you. But not all will or can. You can look it up at your manufacturers website to know for sure.
Good Luck...and I hope this helps you.
Mar 13, 2011 | Vacuums
TIMEX T611T IS SET FOR THE OLD DAYLIGHT SAVINGS TIME. HOW DO YOU CHANGE IT?
I do not believe this can be fixed. From the user manual:
http://www.timexaudio.com/pdf/T611IB59075_73.pdf
Page 10 says:
Note: The clock and calendar automatically adjust for daylight-saving time and leap years. If you live in an area
that does not follow daylight-saving time, you will need to reset the clock when these adjustments occur.
Maybe acknowledging the intractability of the problem is the solution in this case.
Mar 20, 2009 | Audio Players & Recorders
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Aug 19, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Emerson Smartset Radio Model CKS2288
The Daylight Saving dates appear to be hard-coded per the manual:
Start of Daylight Saving Time:
At 1:59.59 AM on the first Sunday in April, the clock will automatically advance to 3:00 AM.
End of Daylight Saving Time:
At 2:59.59 AM on the last Sunday in October, the clock will automatically reset to 2:00 AM.
So the easiest thing to do is to change your time zone up or down one for the period between the new DST date and the old -- or you can buy a new SmartSet for about $15. The newer ones do not have the same problem.
Oct 29, 2007 | Emerson Smartset Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Calendar times advance 1 hour when sync
Check daylight savings time on the laptop
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
La Crosse Radio Controlled Atomic Clock Logo
159 people viewed this question
Top La Crosse Home Experts
Lawrence Oravetz
Are you a La Crosse Home Expert? Answer questions, earn points and help others
