Question about Mitel 5330e IP Phone 50006476
How can I get my wireless headset CS520 model to answer a call without having to lift the phone receiver first?
I have a Plantronics CS520 wireless headset. The Plantronics tech said there should be a button or a code on the mitel phone that should allow my headset to answer a call without having to lift the mitel handset. I am not finding any such thing.
Posted by Maren Bourelle on
danoyachtcap
    Top Expert:
  • 2,907 Answers
There is an "Auto Answer" switch next to the phone connector.
Mayb e this is the one you need.
Posted on Mar 29, 2015
  • danoyachtcap
    danoyachtcap Mar 29, 2015
    There is also a "Call Control" button in the center of the boom mike pivot.
  • danoyachtcap
    I think you have to have the "Lifter" that you can purchase with it.
Scott Baldwin
    New Friend:
  • 14 Answers
A headset button can be added to the phone that when pushed will activate the headset port on the phone. Once added the light will light when headset mode is active. This button can be added through the multi-line set key assignment for in the mitel. I would also suggest added a release button at the same time as the release key would be used to disconnect a call in headset mode.
1 Related Answer
Mark Compton
  • 378 Answers
SOURCE: plantronics cs60 cordless headset not
I'm sorry for being long on my answer here...
The bad thing here is that the CS60 is not a Mitel approved/supported headset. The only headsets that are approved for Mitel Superset or Mitel IP telephones are the Plantronics Polaris model.
BUT many other headsets do work with Mitel telephones. Since they are not "supported" by Mitel, you should contact the headset manufacturer for configuration guidance. Some have dip switches, or dials that need to be in certain positions to work with certain telephone models. This can be different from one phone to another.
Plantronics web site and their support people should be able to guide you to configuring this headset properly for each model phone.
How is the headset and handset connected? It sounds like the CS60 is connected to the handset port of the phone and the handset is connected to the CS60. When you go off hook with the handset, it sends the signal to the CS60 and depending on the switch on the CS60, it will send the signal to either the handset or the headset.
OR
The CS60 is connected to the handset port and the handset is connected to the headset port. To make the headset port work, you must have the CS60 connected to the headset port and the handset connected to the handset port. Set the phone to Headset mode.
Posted on Apr 22, 2011
How do I auto answer using Plantronics Headset (Savi W740) on a Mitel 4250 Phone?
Plantronics makes an adjunct device that attaches to the telephone base (Velcro) and can lift the handset when the button on your headset is pressed. Unfortunately that's the only way to directly integrate the Plantronics (or any other brand) headsets with the Mitel 4XXX series phone. This handset lifter is actually bundled with some of the SAVI headsets, depending on the actual model you get. Separately it's about an additional $50 option. I recall the Plantronics part number is HL-10. Hope this helps.
Jun 19, 2014 | Mitel Lands Phones
Plantronics CS55 Headset
Office was wired that way i have one tried several ways to use it without the lifter did't work had to buy a lifter the next problem is the phone not all will work Cisco uniden will work good
Jun 18, 2014 | Plantronics CS55 Wireless Headset
When I put it on the charger the red light flash on off the whole time without stopping and I get no charge on them
To answer a call, Briefly press the call control button.
When you receive a call, your phone may ring before your headset rings. Wait until you hear the ring in your headset before you press the call control button to answer the call.
Good luck from Headsets Direct - 800-914-7996.
Aug 20, 2011 | Plantronics Backbeat 903 Bluetooth...
I have a CS70 NC./ no lifter. What is the set up procedure to use my headset without lifting my phone handset. With the base plugged into the headset port of the phone.
If the Plantronics CS70N wireless headset is plugged into the headset jack on your phone, you will need to push the headset button on the phone and then the call/control button on the wireless headset.
Good luck from Headsets Direct!
Jun 10, 2011 | Plantronics CS70 Wireless Headset
Hi, At the office we have a Mitel IP phone we have just bought a headset model JAC0021201- B. We cant get it to work. Please can you advise how we set this up. Regards Trevor
I'm not finding manufacturer detail on this headset, only sales via Amazon, and it's dicey info at that.
So,I'm not certain this headset is compatible.  The only Mitel approved headsets are the Plantronics Polaris models.  These headsets fit into the headset port.  Such headsets require a headset button to be programmed and enabled on the phone to work.  When the phone rings, you will have to press the ringing button, to hang up, you will have to press the cancel button.
Other headset models may work, but require them to be plugged into the handset port and the existing handset will have to be plugged into it's unit.  Such units will require lifting the handset to answer the call and hang it up when completed.  Some such units have an optional lift kit.
I personally use a Plantronics Polaris "in the ear" model.  Plantronics web site has a config guide that will help you select a headset.
http://www.plantronics.com/us/configurator/default.jsp?use=Deskphone
good luck,
Mark
Mar 16, 2011 | Mitel 5220 IP Phone
My Headset does´nt have dialtone, I was connecting to cisco phone 7941, 7970, 7911, and nothing, not work.
You can use a Plantronics S11 headset with a Cisco phone, however it is not the best compatible solution. To use an S11 with a Cisco phone, you have to make sure that you are plugging it into the handset receiver jack and not the headset jack. You will need to lift the handset receiver, set it off to the side, and then hang it up after each call. If you want a more compatible solution that you can plug into the actual headset jack and just press the headset button on the telephone to answer and hang up, then you would need one of the Plantronics "H-series headsets" with the Plantronics Cisco direct connect cable ( model 26716-01 ).
Plantronics 26716-01 cable
Plantronics H Series Headsets
Aug 12, 2010 | Plantronics S11 Headset
Plantronics CS55 requires lifting handset on phone
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
May 28, 2009 | Plantronics CS55 Wireless Headset
No Program folder for Plantronics application / driver.
The CS50-USB from Plantronics extends wireless freedom to your softphone. It’s the first wireless headset for VoIP applications with remote call detection and answer/end capability via PerSonoCall software (built-in).
Enjoy yourself without bothering about software!
Jan 05, 2009 | Plantronics CS50-USB Professional Headset
Plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
Aug 04, 2008 | Plantronics PL-CS55 Wireless Headset
Best Buy: Plantronics Problem
James, plug the phone cord that comes out of the back of the CS55 base into the handset port of the Cisco phone, not the headset port.  Then plug the coily cord from the cisco receiver into the front of the CS55.  Don't use the "Headset" button on your Cisco phone, just lift the receiver off.
Mar 21, 2008 | Plantronics PL-CS55 Wireless Headset
Mitel 5330e IP Phone 50006476 Logo
654 people viewed this question
Top Mitel Computers & Internet Experts
Vincent G
Vincent G
ray gallant
Marvin
Marvin
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
