When I turn on my comfort zone heater the numbers on the front of the heater will keep switching back and forth,there is a clicking sound everytime this happens.The heater won't heat up and the fan won't cut in,any info would be appericated....
The E1 error code on a Comfort Zone CZ220 heater indicates a problem with the high-temperature limit switch. This switch is a safety feature that shuts off the heater if it overheats.
To clear the error code, you can try resetting the heater by unplugging it from the power outlet and waiting for at least 30 seconds before plugging it back in. If the error code persists, it may indicate a more serious issue with the heater that requires professional repair.
turn on heater ao5 comes on hit temp switch clicks but goes back and forth from ao5 to temp degree is it the printed circuit board please email at [email protected]
Pulled side covers and followed the power to switch with small red button. Had power on 1 side none on other. Pressed little button and started working
What is wrong with my ComfortFurnace heater if i have it turned off and it still keeps blowing ,Yet if i plug it back in it still comes on and i can turn it way down with it down on 55 and it will not shut of like it use to?
Everytime I turn on the CZ heater, the display reads A05 and then it goes away when i set the temp. As far as I can see and feel, I'm not experiencing any issues with the heating, fan, or thermostat or the extension cord running hot. I'm concerned that something could be wrong or unsafe, with Comfort Zone filing for Chapter 7, anyone know who is offering support or a number I can contact?
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
