I need little help with Datamax printer. I have encountered an issue with Datamax printer. On datamax printer screen it come up with error Position fault and Ribbon fault. I have changed the ribbon of the printer and still no luck. i checked the paper as well and seems to be on right place
SOURCE: 4208 Datamax M Class printer Problems
Check inside the green guide (sensor) for pieces of label. That will block the sensor. If the sensor is reporting a thickness which is double (250) what you expect, then that is definitely the issue.
SOURCE: datamax allegro2 error
if you have it set to use thermal ribbon and dont use 1 then you can get this error..
put a ribbon in or there is a switch located inside the case near the feed switch turn it off
SOURCE: will not feed full length of label. display reads
You may need to take out the whole ribbon assembly by removing 3 screws. The ribbon sensor looks like a L shaped clear plastic glass.
If still not working. buy the ribbon assembly.
SOURCE: datamax dmx-i-4208 (ribbon fault)
Re-calibrate the printer. If still not working, take out the ribbon assembly by removing 3 screws and check the sensor ( "L" shaped plastic glass). If still not working, buy a new ribbon assembly.
