Question about Phoenix Gold Car Audio & Video
Phoenix gold amp audio settings
How do I adjust audio settings
Posted by paul mc on
5 Related Answers
Anonymous
  • 631 Answers
SOURCE: phoenix gold xenon 1200.1
Most of them are NE5532s. There's one NJM13700 also.
Posted on Apr 23, 2008
Anonymous
  • 109 Answers
SOURCE: hi..phoenix gold x600.1 went into protection
Contact Phoenix Gold at 800.950.1449
Posted on Jul 17, 2008
Anonymous
SOURCE: need to find a manual
am trying to hook up two kicker 12 cvr
Posted on Oct 09, 2009
sywright
Sy Wright
  • 112 Answers
SOURCE: my phoenix gold x200.4 amp
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Posted on Sep 23, 2010
    Bill Shrum
    SOURCE: hooking up my phoenix xs 2200 car amp
    red wires go to ur battery and speaker wires go from back of amp to back of sub and there should be a cable that goes from the head unit to the back of the amp.
    Posted on Mar 08, 2012
    How do I hook up this darn Phoenix gold octane r 8.0.1 amp it's supposed to be a monoblock amp but has 2 hook ups 2 positives and 2 negatives I'm thinking that would be to hook up 2 4 ohm speakers to equal...
    Most mono amps now a days give you multiple terminals. The older amps were a pain trying to stuff all the wires in one set of terminals. If the amp is rated at 2 ohms mono then make sure what ever configuration of speakers your running does not go below 2 ohms using both terminals. For example do not hook a 2 ohm load to each terminal. 2 ohms period between the 2 sets of terminals.
    Feb 12, 2018 | Phoenix Gold Car Audio & Video
    Amp not working, subs just thumping
    U either have a bad ground inside your amp or radio or your rca's on the amp are loose
    Feb 09, 2010 | Phoenix Gold RSD600.1 400W x 1 Car...
    Problems with the rca's on phoenix gold 500.2 amplifer
    squeeze the outer cup prongs a bit tighter or replace the cable with a new on that fits tight.
    Apr 01, 2009 | Phoenix Gold Tantrum 500.2 Car Audio...
    Phoenix gold ms2125 amp blown?
    The following is a forum dedicated to PG amps. Someone there will be able to suggest a tech that's familiar with the amp.
    http://phoenixphorum.com/
    Let me know if you have any other questions.
    Aug 18, 2008 | Phoenix Gold Limited Edition MS2125 TA...
    Crossover
    i have lost my manual to the phoenix gold 600.1 xenon amp. i want to set it up by the book can you help me ?
    Apr 25, 2008 | Phoenix Gold Xenon-600.1 Car Audio...
    Car Audio & Video Logo
    Top Phoenix Gold Car Audio & Video Experts
    Steve Sweetleaf
    Steve Sweetleaf
    Tom Chichester
    FastHarley
    FastHarley
    Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
