Question about Kohler Home
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Kohler k1357 lA/RA
gbob59
  • Kohler Master
  • 3,063 Answers
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Posted on Mar 08, 2015
I changed out my Kohler shower diverter cartridge because it was leaking after doing so when you open any faucet in the house it will leak the more faucet you turn on the faster it leaks. The lady plumber...
did your old diverter have a shut off knob on it? if so you may have not noticed it leaking, -what causes that is the existing shower faucet may have been mounted to high from the spout below -or the pipe going down from existing fixture to the tub faucet spout pipe may not be at least 3/4", -if its 1/2" it will always do that
Sep 06, 2017 | Kohler Home
Customer installed a kohler tub/shower faucet and it leaks out of the head. We've changed the cartridge but the results were the samr.a Any recommrndations?
If it leaks out of the shower head and not the faucet tap, then I would look into the scald guard setting or the selector lever or even for a small scratch around the cartridge.
Jul 16, 2011 | Kohler Plumbing
Kohler rite temp with diverter. When the tub is turned on water leaks out the shower head. Changed the diverter didn't fix problem.
You could have a restriction in the tub spout or just too much pressure. Diverter only restricts flow to tub spout so any restrictions to the tub spout will cause water to go up to shower head.
May 13, 2011 | Kohler K-T396-4-BRZ Devonshire Single...
I have a kohler jacuzzi tub and many times over the past 5yrs the pump continously trips and the jacuzzi will not start. Any suggestions i have tried to reset the button unplug and plug it, an filled it...
Sound like your pump may have a leak into the electric motor part of it through the shaft seal.
Or it could just have junk stopping up the lines or the pumps impeller. Hair often finds it's way into these things and screws them up!
If it's leaking there will be some water showing below the pump unit.....
Feb 20, 2011 | Kohler Home
My 2000 kohler tub drain leaks. The drain itself
Need clarification....the drain leaks to the ceiling below, or it doesn't hold water? If it doesn't hold water, no need to replace the ring. Those can be adjusted. Simply pull up on on the lever and screw it in clockwise. This will lower the stop and hold the water. If it actually leaks below, unscrew said stopper, grab a pair of needle nose pliers and place them in the drain (to grab the strainer) and use another pair to loosen. Once off, clean around drain and clean strainer, apply plumbers putty to the strainer, apply pipe "dope" (thread sealant) to the threads and tighten back in. Good luck!
Nov 25, 2009 | Kohler 1107-R-0 ProFlex Bath Tub with...
Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Sep 27, 2009 | Kohler Fairfax Single Control Lavatory...
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks. this unit has been recently installed within the last week
You say that it doesn't leak during showers. The next step is to plug the drain 100% so no water will drain thru the drain assembly. Fill the unit up to just below the overflow drain and leave overnight to see if it could be leaking from the outside of the drain plug assembly or leaking from the jets/drain from the whirlpool feature. If was just recently installed was it professionally installed. Should be covered by warranty.Try this then if its not determined what the cause we will go to the next level of investigating what it could be.in it peak all around to see where the water is comming from. Use a flashlite so your not kneeling in mosture with a electrical light in your hand!!! Good Luck!
Jul 04, 2009 | Kohler Model 7202: Drain For Purist® Baths...
Bathtub leakes when the drain plug is activated, no leak when not
This usually is caused by a detiorated O ring that compresses to make a watertight seal at the transistion points from them drain shoe and overflow tube to the trap adapter. However it may be the trap adapter as well. Either way the best solution is to access the tub waste from the wall behind the tub drain and replace the necessary parts. Your issue is showing up because the gallons per minute/hour rate that the tub drains is far greater than the tub valve is allowed to fill the tub. This causes a greater volume of water to fill the tub waste and as such the backpessure is greater as the entire volume of water in the trap weir must be evacuated as opposed to when the tub is not plugged and the valve is ran requiring the trap weir to evacuate gradually. Some tub wates are made of metal and may have developed holes in them but they generally form along the pathway the water uses to drain. Unfortunately the only real solution is gain access to the tub wate and replace the defective part. Thanks for using Fix Ya.
Mar 10, 2009 | Kohler Model 7202: Drain For Purist® Baths...
Home Logo
354 people viewed this question
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
