This was posted here on Fixya, but the OP updated and said a $3.00 fuse fixed it! Guessing there is a glass fuse on the mainboard.
This kind of Manual High Limit issue can most likely be caused by two things :
1) If it's a Knight XL (399MBH and up), it's equiped with a manual high limit with is located in front of the boiler, behind the front panel just under the display bezzel. It has to be adjusted and reset (with the manual reset button on the control display).
2) If your unit is NOT equipped with that kind of Manuel High Limit, this message means that there was a low voltage wire that was shorted to the ground. Either the flow switch or the thermostat wire. The 24v fuse located on the main control board burned to protect the components. Lucky, Lochinvar provide replacements in the small plastic bag attached to the connection board.
Hope this help. Even if I'm late.
https://www.google.com/search?q=LOCKED+OUT+MAN+RES+HI+LIMIT
