Question about Orion1934 19" TV
SOURCE: Need universal remote code for ge remote and Orion tv
The code that worked for me was 135.
Other Orion codes are 035, 121
Four digit codes for newer remote models might be one of the folling.
0236, 0179, 0463
Good Luck!
Posted on Feb 20, 2009
SOURCE: I can not get my dish remote to work my orion tv , need codes
Try these codes.
DISH CODES
908, 899, 834, 756, 754, 726, 721, 720, 694, 687, 227, 221, 220.
Posted on Mar 06, 2009
SOURCE: orion tv codes
try these codes for the orion tv:0121,0135 or 0035. good luck
Posted on Mar 23, 2009
SOURCE: remote code orion tv/vcr # tvcr0950bw
I had a bugger of a time trying to solve this exact same problem. I went through 3 universal remotes before I found a winner. Using the Jensen Surf Series SC-340 I managed to figure out the code for the vcr to be 687. This is not listed in the manual that I looked up for the remote, probably because the remote was made in 1997 while the tv/vcr is 1998. After trying the ~30 codes in the manual I set the remote to auto scan for the code. After 30min scanning for the tv code I switched over to scan for the vcr code. Three minutes later I get the code and that "Oh yeah. Who got this bad boy to work? You did! That's right!" kinda feeling. I hope this helps.
TLDR: I got a Jensen Surf Series SC-340 Universal Remote to work with the tvcr0950bw using the code 687 on the vcr.
Posted on Oct 03, 2009
SOURCE: have 8 yr old Orion tv-new remote control for
We would be happy to help you with getting your new DISH Network remote to control your TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Orion TV; here are some of the codes we currently have for it: 720, 748, 748, and 748. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Orion TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Mar 09, 2011
