Dryers Logo
Mike Posted on Mar 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Minerva 44" Fan. I have Vaulted Ceilings with a 12-12 pitch. The down rod is 3/4 in. What slope ceiling adapter is recommended ?
tractorman44
Level 2:
  • Expert 484 Answers
  • Posted on Mar 10, 2015
tractorman44
Expert
Level 2:
Answers
484
Questions
Helped
205748
Points
843
Mike, a 12/12 pitch is 45 degrees. You may have to use a little math to figure out how far down to hang the 44" fan to keep from hitting the angle of the ceiling. Geometry specifically. Remember the A sq + B sq = C sq for figuring the hypoteneuse of a right triangle?? If the ceiling fan is 44", the base (A) of the right triangle is 22" with NO CLEARANCE to the angled ceiling. A 45 degree angle dictates the base and the height are equal, so height (B) of the triangle is also 22" with NO CLEARANCE. If you want a few inches of clearance, extend the height by 4" and there should be enough clearance to allow the fan operation.
I would suggest playing with the figures before you buy the extension rods though. The simple answer to you question remains however...45 degrees.
1 Related Answer
Anonymous
  • 6 Answers
  • Posted on Mar 26, 2010
SOURCE: Similar problem: Does Hampton Bay Vaulted Ceiling Mount exist?
Ok so here is the deal. No there does not seem to be a Hampton Bay specific mount. The mount that comes standard in most of the Hampton Bay fans can handle the angle of most standard (read: small) angles. I do not know if it will be the case with all Hunter products, but the adapter for the Hunter fan that I replaced, worked with my new Hampton Bay. So now, I have from the downrod up is from the original Hunter fan. Hope this helps.
Hunter ceiling fan 22450 no reverse switch manual says there is.
Model 22450 does not have a reverse motor. The blades are spring loaded. You change the blade pitch by pushing in and twisting. This will change the air flow direction.
2answers
Our vaulted living room ceiling has black smudges coming through the paint...we have used Kilz paint and repainted several times...also had vents put in the roof
Did you happen to spray the mold with Bleach before covering up ? If mold is still in growth mode even Kilz cannot keep it from penetrating.. Usually half water and half bleach would be ok. Just vent the house well.
We have a Hampton Bay 60 in. Brookdale II ceiling fan and it did not include the 4 inch rod needed for 8' ceilings.
You should be able to get a down rod from Home Depot.
The down rods are similar from other suppliers like Lowes, or any lighting suopply store. Just bring the fan with you to be sure that they are the same size, and have the same attachment method.
Hampton bay vaulted ceiling mount adapter? Do they exist?
If you have a Menards Home Hardware store in your area they will stock this item. Home Depot, Lowes, & Sears Home Centers may have them too
1helpful
2answers
1helpful
2answers
Removing a fan...
on that base if you push it up aganst the ceiling and turn it clock wise then the base cover shoud release and slide down the rod
Just bought a Alture can I get a short rod since our ceilings are
Yes, you should be able to find a shorter fan rod at Home Depot or Lowe's or other building supply stores. If not you could possibly shorten the rod that came with the fan by carefully measuring how much needs to be removed, disassembling the fan and using a hacksaw to cut the rod to the length you need.
4helpful
I want to hang the fan on a cathedral ceiling with a steep slope. Two questions, is the angle of the slope measured from vertical or horizontal,and does anyone make a kit for my fan to hang because the the...
The slope is measured off the horizontal plane. A 45 degree slope would rise 12 inches for every 12 inches of horizontal travel in this example. If the slope is too great try checking kits made by Fanimation. The Fanimation SCK52 - 52 Degree Ceiling Slope Ceiling Fan Kit will go up to a 52 degree angle ceiling and will fit most downrods. The hampton bay fans are very popular and should work just fine with this kit.
-Mark
2answers
Ceiling design Plank and beam with pitch
I am not sure what Punch Plat you are using, however these are some notes and solutions that may help
1 - Crown moldings in Punch don't slope
2 - Ceiling beams --> check your Power Tools--> If your version has the Celing designer, you can use this tool to create the beams--> or use solution # 3
3 - Ceiling beams --> you can cevelop them in the 3D Workshop Power Tool --> set the pitch--> texture as necessary
4 - You will find ready to use beams in --> Obejcts--> Faux Wood beams
Top Dryers Experts
john h
