Are there any images of belt orientation as belt was severed and off pulleys
The drive belt on a F/L washer is normally quite tight and when installed will need to stretch slightly to maintain it's tension.
If you have the correct belt you should be able to make it fit by fitting it onto the motor pulley and then holding it onto the large pulley while at the same time rotating it to get it in place.
Make sure you have the correct belt by checking the belt length. The belts will have a series of numbers which should compare, even if the brands differ.
A belt which is too tight can cause the motor bearing to fail prematurely.
Good luck.
Nomess
Cable ties can also be used...
