How can I make my juicer work again.
My juicer just stop while I was juicing one day. I pulled the plug off the wall and seated for a while. The next day I was trying to run it so I plug it back and I saw the power from the juicer is on GREEN. when I press the ON button it did not run and after like 20 seconds the light on the juicer turn to red and flashing. I tried to press the reset button underneath but doesn't help. What do you think is wrong with my juicer?
Posted by julio cuenca on
sahoo_sanjay
    Master:
  • Office Equip... Master
  • 553 Answers
Dear julio
The reset switch is a thermal circuit breaker, I think the juicer is jammed so the reset switch cut off it generally takes a minute or two to cool down after that it reset.
Therefore you unplug the juicer from the mains try to clean the bowl, try to rotate the spindle by hand if it moves fit the container and reset the switch again(when you push it you may feel a knocking/click). Plug the juicer and test.
Thanks.
Posted on Mar 08, 2015
My Acme Juicerator suddenly stopped working. I am worried the motor burnt out. What should I do?
Acme 5001 Supreme Juicerator Juice Extractor Stopped ...
www.fixya.com > ... > Acme 5001 Supreme Juicerator Juice Extractor
Acme 5001 Supreme Juicerator Juice Extractor, stopped working related issues. ...My motor just suddenly stopped working. what happens if a screw peg ...
Acme 6001 Juice Extractor Juicer stopped working - Questions
www.fixya.com > Forum > Juicers > Acme > Acme 6001 Juice Extractor
Acme 6001 Juice Extractor, juicer stopped working related issues. Get free help, solutions ... ...juicer just suddenly stopped working. Mine stopped working after ...
Amazon.com: Customer Reviews: Acme 5001 Juicerator ...
Dec 03, 2015 | Sponge & Chamois Just Swipe Chamois Lens...
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
Philips Avance Juicer 1871 has just completely stopped while juicing lemons - its been cleaned and nothing is stuck, what should I do? Its only 3 months old.
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
May 17, 2012 | Juicers
After juicing a few carrots[some of which were cut on a slant], or several spinach clusters, the machine seems to get off balance and begins shaking violently and making a racket at which point I have to...
There's nothing wrong. These juicers do not eject the pulp and go out of balance very
easily. If you continue to have problems you may have to go for a different type of juicer.
The Hurom or Omega VRT, expensive, look good if you're really into juicing.
Mar 05, 2011 | Omega 1000 Juice Extractor
Was just juicing carrots and the motor stopped , now when i switch on all i hear is a whir sound but I dont think it is rotating at all what should i do to get it working again?
I am having a similar problem, turned it on to juice carrots, it sounded like it was rotating very slowly then the motor just stopped. Would love a fix, i am addicted to my juicer and would be very sad if it was not good. It is only about 2 months old.
Jul 15, 2009 | Jack Lalanne Power Juicer (Stainless...
Omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
Jun 30, 2009 | Omega 8005 Juicer
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
Jack LaLanne power juicer 250 no longer works.
The stainless bar should be on the correct slots on top of the juicer. It has a safety switch on those bars. Smell the motor from under the juicer, it should not smell like burnt. Press hard on the switch, it might be loose.
Jan 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Juicer blade stops intermittently
you are pushing too hard, this machine likes it slow.
Dec 15, 2008 | Champion 2000+ Household Juice Extractor
51 people viewed this question
Marvin
Marvin
