Uninstall the App. Or clear App Data and Cache. Settings > Apps > All > Facebook > Clear App Data and Cache. Then go to Facebook.com and request to cancel your account.
Hello Sir
plz go to main menu then go to settings and look for call barring option in any of the following submenu.
View missed, received, dialled calls
Recent Calls
Activate call waiting
Settings > In-Call Setup
Divert calls
Settings > Call Divert
Send or withhold number
Settings > In-Call Setup > My Caller ID
View own number
Settings > Phone Status
and then from the CAll Barring menu select cancel
I hope it will help.
Thanks
hi, Before you can activate these barring services you will need a barring
code from your service provider. Call Barring can not be activated if
Call Forwarding diverts are already in use.
To Activate: * 330 * BARRING CODE # [SEND] To Cancel: # 330 * BARRING CODE # [SEND] To Check: * # 330 # [SEND] All Outgoing Calls To Activate: * 333 * BARRING CODE # [SEND] To Cancel: # 333 * BARRING CODE # [SEND] To Check: * # 333 # [SEND] All Incoming Calls To Activate: * 353 * BARRING CODE # [SEND] To Cancel: # 353 * BARRING CODE # [SEND] To Check: * # 353 # [SEND] All Outgoing Calls To Activate: * 33 * BARRING CODE# [SEND] To Cancel: # 33 * BARRING CODE # [SEND] To Check: * # 33 # [SEND] All Outgoing International Calls To Activate: * 331 * BARRING CODE# [SEND] To Cancel: # 331 * BARRING CODE # [SEND] To Check: * # 331 # [SEND] All Outgoing International Calls Except To Home Country To Activate: * 332 * BARRING CODE# [SEND] To Cancel: # 332 * BARRING CODE # [SEND] To Check: * # 332 # [SEND] All Incoming Calls To Activate: * 35 * BARRING CODE # [SEND] To Cancel: # 35 * BARRING CODE # [SEND] To Check: * # 35 # [SEND] All Incoming Calls When Outside Home Country To Activate: * 351 * BARRING CODE # [SEND] To Cancel: # 351 * BARRING CODE # [SEND] To Check: * # 351 # [SEND] Canceling All Call Barring # 330 * BARRING CODE # [SEND]
You need to call orange, they will send an invisible service message to the handset to cancel off the icon, I work for Orange, we do not cancel your voicemail, merely stop calls diverting to it, so if you had an unread message before you rang to stop it it will still be there. Ring 123 to see if you can still listen to the voicemail and delete it, if this doesnt work then call us and get us to send out a voicemail spool cancellation message.
you will need a new sim card for pay as you go, you will also need the PUK code which is supplied by your service provider (bt) to unlock the phone for use with other networks.
just do a master reset you must have put a junk program and makes the whole system go out of its mind so just master reset but make sure you have all of your stuff backed up on it and what messed mine up was the weatherbug app which is so lousy
