Question about Ovens
I have a parmco ar900leg gas stove with a multi function oven power. Its been cooking a treat for the last six months when we bought it. was installed by a gasfitter and correctly. Now, the bottom element is not working. to use the fan assisted baking mode nothing works except for the light and fans. No heat is generated. Put it on fan/grill it works perfectly. can you help?
Posted by Parehuia Wharepapa on
  • Parehuia Wharepapa
    Parehuia Wharepapa Mar 12, 2015
    Hi Jhonny - the hobs are gas and the oven electric. Yes, the fan grill and ordinary grill works. But I notice both wont' work together (ie bake).
Jorge Rendon
  • Ovens Master
  • 5,420 Answers
U say element not working? so its a gas and electric? If so check the element with a multi meter for continuity. I would say check ur gas safety valve also but u say it does work in grill?
Posted on Mar 11, 2015
5 Related Answers
Robert Hirst
  • 833 Answers
SOURCE: Fan oven element
The test is fairly straight forward: Make sure the unit is off. Generally, there is a screw which holds the element in place near the connector. Remove it and the element will slide out. Now, use a resistance (Ohm) meter and measure the resistance across the terminals. If the unit is visibly damaged or you get no reading (use the 1 K ohm scale), change out the element. If the unit tests good, suspect the control or the wiring from the control to the element.
Posted on Dec 31, 2008
douglas smith
  • 1462 Answers
SOURCE: oven no heat
for king louie
fault is the circular element round the fan. take off the back plate inside the oven and you can often see the damage but not always. to get at the terminals, remove the rear cover and test for continuity across the element with a multimeter - remove any connections before doing this and note down where they go
for tarzantony.
i can't remember where the cutout is but probably on top of the oven or close to the fan on bthe back. just trace the wiring from the element and it should lead you to it
Posted on Jul 06, 2008
Anonymous
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    Anonymous
    SOURCE: Baumatic BT187ss Oven All working EXCEPT fan assisted cooking
    I have a similar problem with my Zanussi and discovered there is a seperate element arounfd the fan wihich I think may be burnt out. Could be a similar fault have you investigated behind the panels in side the oven?
    Posted on Mar 08, 2009
    Adrian
    • 109 Answers
    SOURCE: not heating in fan forced mode
    Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
    Posted on Jun 16, 2009
    Gas oven stopped working
    Sure i will be able to provide you solution
    Apr 15, 2008 | Ovens
    How do I stop my parmco wall oven from turning off doing cooking
    I am having the same issue. I can only cook in it for an hour to two hours at 180 deg and after that it keeps turning itself off
    Feb 19, 2015 | Ovens
    Bake, broil & clean buttons do not function, all others (timer, cook time,end time, clock) work fine. Therefore I cannot light the oven. The stove burners work fine.
    check the main power terminal block and make sure the power is correct.if the power is correct then you will need to change the main control board.how ever unplug the unit and check all the wiring to the control board and the bake and broil elements.if the unit is gas then you may need to replace the ignitor unit if it does not draw enough power during the light up it will not open the gas valve.replace the main main control board still applies if the other items check out fine.
    Nov 03, 2010 | Kenmore Ovens
    1937 anitque American Stove came with Magic chef cook book and Loraine thermostatic temperature regulator. Having problems getting Oven pilot light to light. Have checked thoroughly for leaks but have...
    THE PILOT LIGHT IS IGNIGHTED BY AN ELECTRICAL WIRE THAT IS LOCATED BESIDE THE GAS JETS SO MAKE SURE THE ELECTRICAL IGNITION SYSTEM HAS POWER YOU NEED TO LOCATE THE WIRE AND FOLLOW IT TO FIND THE POWER SORCE THEN CONECT THE POWER SUPLY TO IT , GOOD COOKING.
    Nov 22, 2009 | Ovens
    I have a gas oven whirlpool sf3020ekq2 buners work but oven won't
    Sounding like your hot surface ignitor is getting bad. What I would like for you to do is open the oven and take the bottom panel off. This is so you can see the hot surface ignitor. Turn the oven on and look at the hot surface ignitor it is down on the bottom right next to the burner assembly. Does it start to glow and turn cherry red? This ignitor isn't too hard to replace couple of small screws and two wires. Will have to cut the wires so disconnect the unit from the 120 volt plug. Now if it starts to glow and get cherry red hot then the gas valve is sticking and it is the one going bad. That is a little tougher to replace. Turn the gas off at the source and get your wrenches unscrew the gas valve small space so if you want remove the door by just pulling it off the hinges.
    If unit is old and you don't like it anyway maybe santa would be good to you and replace the stove oven. The gas valve is about 60 bucks or so and hot surface is about 20 bucks. let me know how it turns out.. ken
    Dec 16, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
    Frigidaire Gallery Professional Series - No clock/oven functions
    i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
    Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
    F9 error
    hi there,
    can you tell me the model # on your stove please?
    Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
    Oven stopped working while cooking a meal
    it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
    Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
    Ovens Logo
    331 people viewed this question
    Top Ovens Experts
    Michael Thomas
    Michael Thomas
    Marvin
    Marvin
    john h
    Are you an Oven Expert? Answer questions, earn points and help others
