I had trouble with the heat only blowing warm air. I replaced the sequencer and it fixed that trouble. It was working fine then the blower fan came on with the heat and will not turn off even after the heat goes off and cools down the heater coils. Could the sequence be defective again?
It may be but the fan control may be set to turn off at to high a temp, or theres a short between ;r; and g at the stat or furnace or sequencer, IF it runs through it. A limit or rollout switch may have failed but this will keep the unit from firering. Check for a manual blower switch that may be on. At stat it should be at auto and alsso at the fan control. A stuck relay is always possible,
Posted on Oct 11, 2015
SOURCE: Electric furnace fan works heater does not
coil could be broken. open the cover hold the door switch and look to see if the coil glows when the heater is turned on if not turn off the power then remove the coil then turn on the power and check the voltage you should get 210V A/C on a meeter if you do or yo can do this firs, check for continuity on the coil if you get continuity then check for voltage. if no voltage check the breakers or check the breakers first the electric heater needs two breaker if one is tripped you could have a blower and no heat.
Posted on Oct 09, 2014
Jan 30, 2016 | 1977 Buick Electra
Oct 01, 2015 | Heating & Cooling
Jan 14, 2018 | Cars & Trucks
To
troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp
gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not
working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
Nov 30, 2011 | 2000 Ford Windstar
Feb 21, 2011 | Carrier Heating & Cooling
Dec 28, 2010 | Coleman Heating & Cooling
Jul 06, 2017 | Ruud UAKA060 Air Conditioner
Feb 17, 2010 | 2005 Chrysler Pacifica
Jan 08, 2010 | Goodman CLQ36AR49 Air Conditioner
Oct 10, 2016 | Coleman Home Electric Furnace Eb15b/Eb15d
465 people viewed this question
Hi Anonymous, Imeanthe fan control may be set to low, not too high. Set at 50 f, it will never get that cold to tell it to shut off
there is no adjustment on fan control relay
