Electrolux dx 302 wj. When I turn it on it starts flashing horizontal lights across entire screen
Although you might not still need the info, I still post my findings which might help others.
I had the same issue as you described, I found that the 4.7uf 400v electrolytic cap on the control pcb (c31)has failed, it holds only little of its capacitance and esr has gone up crazy high about 150ohm, simply replace it with same value (pay attention to polarity)and it works as new.
Btw the other 3 brown colour caps are very high quality elna brand ones, they measured good as new, the one(light blue) failed is random unknown brand, no surprise.
Ben you are a genius ?? I had all lights flashing on my DX302 Electrolux Dishlex which is now pushing 13yrs old. I replaced the c31 capacitor with a new 4.7?F 430V capacitor, plugged all the wires back in, screwed the door back together, plugged it back in and I'm back in business!! Couldn't have done it without your advice!! Thank YOU!! ??
SOURCE: Dishwasher Dishlex DX302WB No Hot Water
Thank you This worked for me!
The heater was ok found dry joint on pc board
see attatched photo
Took top 6 screws out of door holding front panel in place
Removed front switch panel
I then labeled the 6 cables with 6 being for the heater
Removed pc board from housing to find dry joint
using small piece of wire and solder repaired board
re assembled
now as good as new
SOURCE: Electrolux DX302 Dishwasher power button wont stay on
I rang Electrolux and have ordered a new switch....
SOURCE: The clean light in my Kenmore dishwasher keeps
It has to do with the water temperture, either the water entering the dishwasher is too cold and the heater can't get it up to temp, or the heater unit has problems... Push the Air dry ,then the sani wash buttons a few times and all the lights will light, it resets the computer .
SOURCE: electrolux dishwasher all lights blinking and wont
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
SOURCE: All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
