Question about Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 215 giving error c2558 - Konica Minolta Office Equipment & Supplies
Posted by Mohammed Raheem on
Rajib Barman Varma
    New Friend:
  • 23 Answers
CHANGE YOUR DRUM UNIT OR DEVELOPER
Posted on Dec 15, 2016
Ngoro
    Top Expert:
  • Konica Minolta Master
  • 2,640 Answers
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Posted on Mar 07, 2015
5 Related Answers
Anonymous
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
herminio_hal
Herminio Halili, Jr.
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Posted on Jul 09, 2009
steve p
  • 44 Answers
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Posted on Nov 29, 2009
Anonymous
SOURCE: Konica Minolta Bizhub c350 error code c-0510
I have this code
C0510 Upper fusing roller abnormally low temp
how can I replace the thermistor in the fuser
Posted on Dec 30, 2009
xeerie
Zaheer Ahmed
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Bizhub 185 c2558 Error how to clean - bizhub Konica Minolta Office Equipment & Supplies
Do not know which application to download on the topic reverse phone lookup? Come here, here you will find all the information. https://besttrackingapps.com/mobile-phone-lookup
Dec 12, 2017 | Konica Minolta Office Equipment & Supplies
Bizhub c224e error code 2558
Konica-Minolta bizhub C224e Code: C2558
Description
Abnormally high toner density detected black TCR sensor
The TC ratio of the toner determined by the toner replenishment control is detected to be the predetermined value or over for consecutive times.
Remedy
1 Reinstall developing unit. 2 Reinstall toner cartridge. 3 Check the connector between developing unit-FRB CN13, CN14, CN15, CN16, CN10 for proper connection and correct as necessary. 4 Check the connector between FRB CN1, CN3-PRCB CN7, CN9 for proper connection and correct as necessary. 5 Replace the developing unit. 6 Replace FRB. 7 Replace PRCB.
http://www.printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20C224e&code=C2558
Aug 22, 2016 | Konica Minolta bizhub Office Equipment &...
How do i clear message c2558 for the konica minolta bizhub 215
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Feb 24, 2014 | Office Equipment & Supplies
Error code c2558 in konica Minolta bizhub 164
help me my konico minolta bizhub 184/164 error (C2558) my mail id [email protected]
Sep 30, 2013 | Office Equipment & Supplies
Error code c2558 for konika bizhub 215
TC ratio in the imaging unit, which is determined by toner replenishing amount control mechanism, is a predetermined value or more for a given number of times consecutively.
check for developer
check TCR sensor
check toner sensor
check the PRCB
Jan 15, 2013 | Konica Minolta bizhub C450P Laser Printer
Konical minolta bizhub 164 mahine service call c2558
machine trouble sevice call [c2558] wat a problam in konica minolta bizhub 164 printer
Jun 02, 2012 | Konica Minolta bizhub C250 All-In-One...
Minolta bizhub 164 error code C2558..how can I solve
my mail id - [email protected]
Mar 06, 2012 | Konica Minolta bizhub Office Equipment &...
What is a service code c2558 mean on my copier?
C2558: Abnormally high toner density detected black TCR sensor
Reinstall imaging unit
Change imaging unit/K
Change PRCB
Sep 28, 2010 | Konica Minolta Bizhub c203 Copier
How do I clear error message C-2558 for the Konica Minolta bizhub C253
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
1,917 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
