I have used GIMP for about 1 and a half weeks now and it has been working just fine. We were just assigned a project where we used the filters. It kept crashing and I have had to restart it multiple times. I kept saying "(Not Responding)" and would fade a little bit and then would force exit. The last time I tried to open it, it started loading about 2/3 of the way, when it came to loading the fonts and then it stopped and came up with something saying "A problem has caused this program stop working correctly. Windows will close the program and notify you if a solution is available. This happens every time I try to open a xcf file or GIMP. I have restrted my computer multiple times and I uninstalled it and reinstalled it, but the same problem is still happening. I don't know how to fix it and I need to submit the project. If someone could help that would be great!
SOURCE: Gimp install
Hi there. Common error. Just uninstall GIMP, re-boot and then reinstall only from www.gimp.com (nowhere else). That should do it.
SOURCE: it keeps shutting down.
First of all, make sure you have enough ram (I know, it sounds stupid, but you'd be surprised). Also, you should uninstall GIMP, reboot and reinstall it ONLY FROM gimp.org! Nowhere else. This is a common problem and happens to all of us from time to time. You can find additional help at:
http://www.cafemom.com/group/18644
and
http://registry.gimp.org/faceted_search/results/date_authored:2009-07
SOURCE: GIMP Error
Review your version, and download from secure sites: http://gimp.org/
Check the root for the new plugins:
Default:
C:\Program_Files\GIMP-2.0\lib\gimp\2.0\plug-ins
User:
C:\Documents and Settings\USER\.gimp-2.6\plug-ins
I hope help you (rated this) Good luck.
SOURCE: When I down loaded Gimp it was working fine Then
Just HOLD CTRL and tap . You could also click on the word WINDOW in your GIMP menu bar and click on dock able dialogs and then layers OR below that click on LAYER, CHANNELS,......
You may repair .psd files with the aid of program can't modifying your original .psd file data during restoration
