Vizio XVT3D474SV 47 in. 3D LCD TV Logo
N
Norma Bean Posted on Mar 07, 2015
When I push the V in the center of the remote, I only get the buffering circle displayed on my screen. i cannot get to my apps. What can i do?
Is remote start built in my Pontiac Vibe vin 5y2sm65846z409024?
Hi does your transmitter have a button on too dead center between lock. Unlock buttons. The logo is like a circle. You should lock doors two times then push and hold circle button down 4 to 5 sec. Parking lights should come on and it will start. Ps if your check engine light is on for any reason remote start is disabled automatically. Until check engine issue is fixed. Hope it's helpful
2answers
How unlocked the icon lock do Nathing when touch the screen
      Lock/Unlock Screen Portrait Orientation Mode - Apple® iPhone® 5. This helps if you can't get the screen/display on your device to flip or rotate. Access the Control Center by touching the bottom of any screen then dragging upward. Tap the Portrait Orientation icon to lock orunlock screen portrait orientation.
      Lock/Unlock Screen Portrait Orientation Mode - Apple ...
      www.verizonwireless.com/support/knowledge-base-64759/ Verizon Wireless
    Feedback
    Lock icon with circle ios7 need to unlock ' Apple Support Communities
    discussions.apple.com > Support > Apple Support Communities
    AppleMay 5, 2014 - Lock icon with circle ios7 need to unlock ... iPhone 5, iOS 7 ... it will
Jan 23, 2016 • Cell Phones
1helpful
I can't get face book news feed on my iPad. I don't have any other computer. All other apps are working.
Generally speaking, you can fix this by killing the FB app. Double tap the home button. This brings all running apps to the forefront, you might have to scroll to find Facebook. Tip, the displayed app will appear in a floating window, and the Facebook Tile will be displayed center screen when you find it. Now, swipe up to shut the app down. This generally fixes the problem.
How do i turn up my back speakers?
Grab the remote for your vsx1018 and press receiver at the bottom of the remote then press the number zero button (this button acts as the channel level function when remote is in receiver mode) you will then notice that if you repeatedly press the zero button that it will cycle through each channel on the vsx1018 display (L for front left, C for center, R for front right, SR for side right, SBR for sarround back right, SBL for sarround back left, SL for side left, and last but not least SW for subwoofer rca jack output to your sub amp. After you have selected the speaker volume you want change ( SBR and SBL in your case) then push the left or right of the circle that sarrounds the enter button on the remote in order the fine tune the volume for each speaker,and after you are finished setting the volume the way you want then push the return button that is to the lower right of the circle that sarrounds the enter button on the remote. Cool huh!! :-) Oh ya, somthing else that is cool about the vsx1018, you can put music from your computer onto a thumb drive and then plug the thumb drive in the the ipod usb and the music will play!! IE press ipod button on remote and then use the circle to change music tracks.
WHEN GRAPHING A CIRCLE ON THE TI83, THERE ARE POINTS MISSING.
Use the DRAW program.
Press [2nd][PRGM] (DRAW)
Select [9:Circle (]
Command echoes on main screen
Complete the command with coordinates of the center and the radiius
Close parenthesis and press [ENTER]
The circle is displayed.
Ex: Circle(0,3,2) draw a circle with cntere at (0,3) and radius equal to 2.
Alternatively: If the conics application is on the calculator run it.
Press [APPS]
Select [Conics]
Select [1:CIRCLE]
Choose the canonical form (X-H)^2 + (Y-K)^2=R^2 where H, and K are the coordinates of the center and R is the radius.
You will be prompted to enter the values for H,K, and R
You can also use the general equation for a circle aX^2 +aY^2+BX+CY +D=0
Enter the values of a, B, C and D.Change the values to get what you want.
Phone screen blank and when on charger circle ring w/3 colors
That means that your phone has corrupt firmware. Please get the firmware reinstalled from Samsung Service Center. That would remove the virus too which may be the cause of corrupt firmware. And after that install an anti virus software too.
1helpful
My 50'' Samsung Plasma has dead screen after only 2 years
welcome to fixya!
without doing voltage checks, my best guess is this:
Plasma hpr5053 or hps5053 models will burn out a buffer board or both, there are two buffers and the Y board.
I usually change all 3 at once, but if on a budget you can try to remove one buffer and see if you get half picture (upper or lower)
this is something only a technician should attempt. the boards cost $200 each (buffers)
$300-$400 (Y board).
if you actually get half a picture the Y and one buffer are good, a bad buffer usually burns out the Y board. and in really bad cases the panel is bad also (not common, but possible)
For part#s , specific help you can post a model# , but again this is a repairmans job not something the average customer can fix.
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
OSD for NAD T752
The blue screen indicates a proper connection (signal received by the monitor). Try selecting "amp" on your HTR 2 remote then use any directional button at the center of the remote, the keys which circle the "Enter" button. Hopefully you will then see the menu appear. Use the same directional keys to navigate the menus.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
