Question about Canon C2058 Color Copier
Canon imageRUNNER C2058 Color Copier/Printer service manual have error e240-0000
Posted by highereyeq on
Ronnie Gregorio
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
E240 Error in communication of controller
0000 Error in communication data Check connector, check connection of sub PCB in the
controller box, check / replace DC controller PCB /
main controller PCB
0001 There is no response when 3 sec passed since the main controller had sent the pickup
request to DC controller during printing.
0002 There is no response when 4 sec passed since the main controller had sent the request
for image output to DC controller during printing.
0003 The engine is activated when jam occurs.
Posted on Jul 09, 2009
What do I do when my printer gives me a error code of e748-2024?
recommended main board 1reseat everything on the boards and the connection between the two there is a comms problem between Cont 1 & Cont 2
Sep 01, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Kindly give me the solution for canon C2020L error code E000002-0006
Detection of abnormal temperature increase in the fixing assembly.
Most of the time just change the fixing assembly. part # FM4-6227-000
Dec 20, 2013 | Canon for IMAGERUNNER C2020 C2050 C2058...
My canon color imagerunner C2050 has a code Eo70-0001 what should I do
Check the home position sensor on the transfer belt. Make sure its not dirty. Also I think there may be some aluminum tape on the edge of the belt for the home position sensor to see, make sure its still there and did get ripped off. I did't actually work on this machine but these are the usual problems on other models.
Oct 09, 2012 | Canon for IMAGERUNNER C2020 C2050 C2058...
My canon color image runner c2050 is giving me a code E070-0001 and need to know what to do about it.
The error means that there is a problem with the transfer belt unit. You may need to replaces the transfer belt unit. You may need a service person to resolve your issue.
I have a E020-04Ao error on a canon c2058. Any
from left to right the last drum has a failure pretty sure this is your black drum assy
Sep 11, 2009 | Canon C2058 Color Copier
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
Error E070 0002
I don't know which model you're having problems with but if it's an IR-C2058 the error has to do with the Transfer Belt. The 0002 says the transfer belt sensor ( S51 ) continues to detect the home postion for transfer belt. I don't know what kind of work you've done to the copier, if any, but the error will have to be cleared up first. Let me know what model and I can help alot more. Good luck.
Feb 11, 2008 | Canon imageRUNNER 400S Copier
Canon C2058 Color Copier Logo
416 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
