Question about Home
Where can I get the installation instructions for this shower please
Phillip Hicks
  • 917 Answers
If you have the Box the unit came in, you should have Manufacture details. Also look at box or instructions for Phone No / Web site /e-mail, etc. Failing all that look in yellow pages for local dealers.
Posted on Mar 07, 2015
Am installing a Moen hand held shower ("Propel"). The instructions say I should install a backflow preventer. Where does that get installed? Inside the wall, or on the shower fixture itself?
Just buy a backflow preventer and install it in-between the pipe coming out of the wall and the shower head. Most (all?) shower heads have 1/2? standard pipe thread. Home Depot sells a backflow preventer with 1/2? standard pipe thread for $6.97.
Good luck and hope this helps.
Dec 27, 2017 | Moen Home
How do I replace a Delta shower faucet with a new one?
should not be necessary to get behind the shower stall as there should be a hole big enough to remove /replace the facet insert
call a plumber in as it may be corroded in place and may require specialist tools for the job
get a quote first
Jun 30, 2016 | Delta & Single Handle Shower Faucet
Is there any problem with using silicone on maax mediterrian III shower walls
I looked at the installation instructions for mediteranean III at this Maax site. It says silicone sealant is to be used. Unsure where you noticed mentioned of siliconized latex.
http://www.maax.com/en/products/showers/showers-kits/mediterranean-iii-tm
Sep 04, 2014 | Maax Breeze: One Piece Round Shower...
Installation instructions for trevi Calista shower column
Where can I get spare parts for the Calista Shower Culumn? One of the joints inside has snapped.
Jun 26, 2012 | Home
Instructions for item rp32539 for instalition
You can get the install manual on link below.
http://common.csnstores.com/common/marketing/delta/dlt1717_maintenance.pdf
Good Luck and please rate 4 thumbs for the free answer
Feb 24, 2010 | Delta RP32539 Chrome Classic Multi...
Need instructions
Sterling has a video on their website that explained what I needed.
Aug 15, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Recently purchased a vista pivot shower door - there are no included instructions 1505D-36NG06
instructions for shower door installations are very important to have,..i have installed over 100 of them and i still wouldn't attempt one without instructions,.your totally best to do the research it takes to get the instructions needed for this job,...there are certain cuts and measurements that are very dependent on specifications given by manufacturer to be right,....one wrong cut domino effects the whole job,....good luck
Jun 11, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Installation 1500d
You can download the installation instructions at http://www.sterlingplumbing.com/onlinecatalog/pdf/1063213_2.pdf Good luck and please don't forget to rate this.
Jan 12, 2009 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
