Question about Yamaha Electrical Supplies
Why does gas come out of what looks to be a vent line from the valve cover on my yamaha yg650de generator
Posted by john wolcott on
1 Related Answer
rwvanlue
Roland W VanLue
  • 486 Answers
SOURCE: My Honda EM650 generator quits running after 15 to
'Vent is leaking while running': can be caused by varnish on the inlet needle/seat and debris in the float bowl.
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 22, 2009
YG650DE Yamaha generator. Fires up perfectly, then shuts down after a minute. Will fire up again, run about 1 minute then shut down. Same thing over and over. changed out gas and oil. Help please
Since most generators are seldom used, gas left in the carburetor gunks up and stops up the passages.
Take lots of pix of the assembly. Pull the carb, remove the bowl and spray carb cleaner in all the holes you see. Don't let it back spray into your eyes. Wear safety glasses. Some holes/orifices may need to have a soft wire passed thru them.
Next time you store your generator, drain the gas, run the generator til all the gas is out of the carb. If you can get to the bowl w/o removing the carb, pull the bowl and spray the bowl and underside of the carb w/carb cleaner and reassemble.
Sep 11, 2017 | Yamaha Electrical Supplies
Yamaha roadstar 1600
One line that comes from the top LH side of carb (looking at carb w/o air cleaner) is a carb vent aprox 1/4 " hose. It connects only to the carb & hangs in a wire bracket as a vent tube. The 1/2 " vent line that goes from the valve cover on the rear cylinder goes to the spigot on the air cleaner case & vents the crankcase gases back into the intake of the carb to be burnt. Those are the only 2 lines other than the fuel line that comes from the metal pipe that crosses over to the fuel pump on the other side of bike. That fuel line connects to the carb metal fuel spigot on the side of the carb. That's fuel into carb.
Mar 26, 2014 | 2002 Yamaha Road Star
2006 Yamaha TTR 125E - carb not getting gas
Remove the gas tank shut off valve and clean it or replace it. The filter in it must be clogged.
Jun 13, 2013 | 2006 Yamaha TTR 125 E
Heater will not stay lit!!!
Lets start with safety. Check your vent pipe for obstructions, mainly outside at the vent cap. The safety of this unit will not allow it to operate if there is anything blocking the vent. If all is OK, then next we will light and observe the pilot with it on the pilot setting on gas valve. The pilot flame should consume the tip of the generator point by 1/2 to 5/8". If it does not, then screw off the pilot adjust screw cover on the gas valve. This is clearly marked on the top of the valve. Inside you will have a much smaller screw. Turn it counter clockwise to raise the pilot level, clockwise to decrease. Never consume more than 5/8" of the generator tip. Hopefully your problem will be resolved here at this step. If however it is OK, then take a millivolt meter and read the generator millivolts, at the gas valve with the thermostat contacts closed. It should read 140 millivolts. You need this much power to properly operate the heater. If it is lower than 140, then replace the pilot generator....Rob Just a note...Do not remove or take apart any part of the Gas valve, other than the pilot adjust screw cover...Good Luck.
Dec 29, 2009 | Williams 3003622 Ceramic Wall Mounted...
Where the fuel lines hook up off the gas tank
The vent line off the bottom of the bowl vents gas when the fuel valve is is opened
Oct 18, 2009 | 1985 Yamaha XJ 900 F
Electrical Supplies Logo
70 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
