I was bought a lamp and replaced it 2 months ago. I was unable to reset the timer, but the projector was working after lamp replaced, now it stopped working with the time over due and unable to reset it. on the timer shows 1917hs.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
SOURCE: Reset Lamp sequence for Sharp XGE-3500U
Hello everyone,
May you tell me how much it cost to buy Sharp XG3000U?
Thank you for all of your time.
SOURCE: light on my sharp xg-nv4su projector comes on for
To reset the lamp timer you:
1. Turn off the main power button on the back of the projector.
2. Hold down the down, right, and enter buttons on the projector.
3. Turn the main power button on the back back on.
4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
SOURCE: I replaced the lamp in
First check your bulb properly matched with your projector. After changing the lamp reset the lamp hour (counting from 0hrs). Adjust the osd transparency. If u set the lamp properly then It may cause the lamp circuit need repair. Have you got yellow lamp indication before change the lamp? If occur then you have been late to change it. If you used it up to 2500hrs. then this problem may arise. Check those first if everything ok then may be the circuit have some problem, go to the nearest sharp authorize service center or visit website.
