Sharp XV-Z9000, XV-Z9000E, XV-Z9000U Projector Lamp - BQC-XVZ9000/1 - OEM Equivalent Logo
T
Tom Lee Posted on Mar 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am unable to reset the timer after replace projector lamp- there are no screen. How to reset the timer?
Lampdeng.com
Level 2:
Renaissance:
An user who is expert in 3 categories / brands.
  • Expert 789 Answers
  • Posted on Aug 22, 2016
Lampdeng.com
Expert
Level 2:
Renaissance:
Answers
789
Questions
0
Helped
197630
Points
977
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on Apr 12, 2008
SOURCE: Reset Lamp sequence for Sharp XGE-3500U
Hello everyone,
May you tell me how much it cost to buy Sharp XG3000U?
Thank you for all of your time.
Anonymous
  • Posted on Oct 12, 2009
SOURCE: light on my sharp xg-nv4su projector comes on for
To reset the lamp timer you:
1. Turn off the main power button on the back of the projector.
2. Hold down the down, right, and enter buttons on the projector.
3. Turn the main power button on the back back on.
4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
Anonymous
  • 1833 Answers
  • Posted on Feb 21, 2011
SOURCE: I replaced the lamp in
First check your bulb properly matched with your projector. After changing the lamp reset the lamp hour (counting from 0hrs). Adjust the osd transparency.
If u set the lamp properly then It may cause the lamp circuit need repair.
Have you got yellow lamp indication before change the lamp? If occur then you have been late to change it. If you used it up to 2500hrs. then this problem may arise. Check those first if everything ok then may be the circuit have some problem, go to the nearest sharp authorize service center or visit website.
How do I turn on my P350x NEC projector and how to reset the timer?
1. To turn on your NEC P350x projector, press the power button on the top of the projector. 2. To reset the timer on your NEC P350x projector, press the Menu button on the remote control. Then navigate to the "Timer Settings" menu and select the "Reset" option.
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Sharp projector timer unable to reset after replaced lamp.
    Have a nice day!
    Jerry
    Lampdeng Limited
    I have a Sharp DT400 projector. I replaced the lamp, and the unit powers on, and displays a picture during warm up but only for a few seconds. The lamp indicator and power lights go back to red and unit...
    If you try to turn on the projector a fourth time without replacing the lamp, the projector will not turn on.
    Press ON, INPUT, UNDO, left arrow, ENTER and right arrow on the projector in order, and then press ON.
    The lamp 0000H is displayed on the lower left of the screen.
    I replaced the lamp, but am unable to reset the lamp so that the projector works again. It keeps giving me the message that I need to replace lamp and reset timer. And then it turns off.
    1. Switch power ON, and press the TIMER button on the remote controller, or the RESET button
    on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear
    on the lamp timer on the bottom of the screen.
    2. Press the MENU button on the remote controller, or the RESET button on the control panel,
    while the lamp timer is displayed. The 'LAMP xxxx ? 0 CANCEL' message will then
    appear.
    3. Press the and select 0, and wait until the timer display is cleared.
    2helpful
    How do you reset the lamp timer?
    Here's how to reset the lamp timer:
    - Press the Menu button
    - Scroll down to the LAMP TIMER RESET option, then scroll right to enter
    - Confirm that it is OK to reset the lamp timer by hitting the OK button.
    - The on-screen menu should confirm the lamp was reset correctly
    You should only reset it after you've changed the projector bulb.
    16helpful
    4answers
    Need to reset lamp. replaced lamp and installed new lamp.
    Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
    3helpful
    4helpful
    2answers
    PT-LC50E LCD Projector
    With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
    I wish they could have stuck this in the operators manual.
    1helpful
    REPLACING MY LAMP
    Hi Big Dogg
    Replace the lamp and reset the lamp timer.
    Lamp timer can be reset by holding down the up arrow key and then following the easy on-screen instructions.
    Top Sharp Office Equipment & Supplies Experts
    k24674
    ZJ Limited
    ZJ Limited
    Norman Weimar
    Norman Weimar
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
