The cold air that you receive to your refrigerator comes from your freezer, so when you normally have a problem with a refrigerator not cooling you would check the freezer first. The first thing I normally check is to see if the evaporator inside the freezer is frozen or full of ice. Some times you can actually see ice build up on the Pana in the back of your freezer. Is the fan running in the freezer? if there is no ice build and the evap. Fan is working then I would check the compressor and the condenser in the back of the fridge. Are they running? If your freezer is iced up you most likely have a defrost problem and would need to call a service tech. To find out which part is causing it. If the fan in the freezer is bad you might be able to do it yourself. If it's the compressor or condenser motor you would need to call a tech as well.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
