Control pod failure on bose companion speakers , the sound stops
Whenever the speakers are the sound stops , and I have to hit the control pod all the time , all my wiring has been checked , everything is plugged properly
Re: control pod failure on bose companion speakers , the...
Check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
Hi, This could just be a sign that your Speaker system is wearing out , and done its due...Also have you had any Power Failures or surge's Lately , if so then it could of damaged the Speakers aswell.. Hope you come right bud Happy new year
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
had the same issue. Trial and error - I tried shorting every pair in the control pod dock with a paper clip. Turns out it is totally possible to bypass. You need two: top row, right side to third row, one from the right (below it by two spaces), and second row (there are only two in the second row, connect them). One tells it to turn on, the other passes audio through. I'm only getting sound from the right channel, so probably need to connect one more pair...
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
