Question about Apple iPod MA446LL/A MP3 Player
My ipod was hang!
When i play a music well hang he do not connect to the computer what can i do?????please help me!
Posted by keian on
  • 16 more comments
  • Anonymous Dec 17, 2007
    i ve the same problem
  • gemskie Dec 19, 2007
    ipod hanged while playing a music
    i got the solution for hanged ipod.. press the menu for 6 seconds... do not press the play menu cuz it will not work.
  • Anonymous Feb 05, 2008
    hang...........
  • kali007 Feb 19, 2008
    i ahve same prob
  • s700i ^_^ prob Apr 13, 2008
    my ipod nano was hang and does not coonect to my computer.....cant also turn off.... what to do? T_T
  • Anonymous Apr 26, 2008
    ipod menu screen only and no butten is working
  • Anonymous May 24, 2008
    ipod hanged
  • Abhi_aj May 31, 2008
    When i connected my iPod (Classic 30Gb) to my computer it hanged and did not turn off also the clicker sound is heard but there is no response to any action
  • Anonymous Jul 07, 2008
    My Ipod nano hanged without any reason. I was using it than i put it into pause mode. When I tried to start again, none of the keys are working.
  • jems306 Jul 07, 2008
    i unplug my ipod from the computer without turn it off. when i try to connect it back the computer don't recognize the device (any other computer cannot either). How could i solve this problem?
    Pompée Jems
  • Anonymous Jul 26, 2008
    i was surfing songs quickly and my apple ipod mini got habged
  • pinch9940 Aug 22, 2008
    when i on the ipod my ipod is hang
  • cyklonez11 Aug 25, 2008
    my ipod haNG WHEN I PLAY A MUSIC
  • Anonymous Sep 05, 2008
    my apple 30 gv vedeo ipod is hanged.when i connect it to computer it is not seen in my computer.There is only one msg on the screen of the ipod .
    DO NO DISCONNECT.
    i have disconnected the ipod but still the same msg is on the screen.
    so what shud i do now?
    ipod completely hanged with the same msg.
    Hoping to get a responce soon.
    Thanks
  • jawadx9 Sep 05, 2008
    my apple 30 gb vedeo ipod is hanged.when i connect it to computer it is not seen in my computer.There is only one msg on the screen of the ipod .
    DO NO DISCONNECT.
    Thanks
  • nadeemsherwa Nov 27, 2008
    when i connect ipod to computer it is not appear in itunes. neither show space in my computer it doesn't open. and when i disconnect i ipod is oning and offing. it does not work. if i reset it is same or it is hang. please help me.
  • Anonymous Dec 10, 2008
    i was hung. Can not use, can not connect to iTune
Anonymous
Ya just hold the menu and center button till an apple image appears on screen!
Posted on Jan 30, 2008
Anonymous
To reset an iPod with a Click Wheel, including: my ipod was hang! - ipodnano3.jpg icon_ipod_5g.gif ipodnano.jpg ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Posted on Dec 20, 2007
Anonymous
My ipod is getting hang i cant switch off how to switch off can u tell me
Posted on Jan 27, 2009
Anonymous
    New Friend:
I was listening a song on ipod after that i hold it.after some time i switch on of ipod bt its not working.it hanged from last 2 hours.i recently install i tunes.may thats reason.now lights of ipod is on bt its not working.
Posted on Jul 12, 2010
Anonymous
    New Friend:
My iPod is malfunctioning... I get it onto my charger for the computer... It shows me a lighted up screen with the White apple on it... Then it powers down... WHAT DO I DO!
Posted on Nov 26, 2009
Anonymous
My 180 gb ipod classic is hung and it displays only charging please wait
Posted on Aug 05, 2009
4 Related Answers
Anonymous
  • 73 Answers
SOURCE: iPod hang
if your ipod is hanging just press the menu and the center button at the same time for about 10 sec and it should reset the ipod.hope thi one helps!
Posted on Dec 20, 2008
Ekse
  • 13434 Answers
SOURCE: my ipod was hang!
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Posted on Jul 17, 2008
issy2
Mohamed Ismail
  • 462 Answers
SOURCE: my apple ipod is hanged when i connected to computer
try performing a soft reset before connecting to the computer and then connect to pc...!!!
Thankyou
Posted on Feb 18, 2008
Anonymous
  • 14 Answers
SOURCE: I have an nano ipod and I can not transfer songs
Be sure you have the latest version of iTunes. You can also try downloading software called Songbird. If none of this works do a hard reset of your iPod and put it into disk mode. You won't lose any of your songs.
1. Disconnect from the computer.
2. Press and hold the center and menu button until the Apple appears on screen
3. Before the Apple is gone, press and hold the center and left back button until it says "Disk mode".
4. Connect and try transferring songs.
If that works, you'll have to reset after you're done. Hope I've helped, I work on iPods and they can be a real pain.
Posted on Feb 24, 2010
Cannot play most music and also indicating invalid file format, open fail, decode error what should i do and can i make it play musics when copied onto de ipod
Most times, people often make the mistake of copying music files direct to the memory of the ipod device.
If you do this, you might be able to detect the songs but your ipod will not play the songs as it may not recognize their format.
For you to copy music files to your ipod, you would need to download the itunes program and install it to your computer.
With this installed, you can connect your ipod to your computer and open itunes. It would be displayed under your itunes program and you can then copy your music files using itunes by dragging them and dropping them on the name of your ipod as it is shown on the left hand side of the itunes program.
If after doing this, you still have the same problem, you can use your itunes to format the ipod and put the songs afresh.
Hope this helps you? Please comment for more information
Jan 21, 2011 | Apple iPod nano
MY IPOD NANO IS FROZEN
i will be glad to assist you with this. If this step doesnt help please let me know and i can instruct you on how to reset your ipod.
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Audio Players & Recorders
Ipod shuffle wont play
If iPod shuffle isn’t playing music
â iPod shuffle might not have any music on it. If you hear the message “Please use
iTunes to sync music,” connect iPod shuffle to your computer to sync music to it.
â Slide the three-way switch off and then on again.
â Make sure the earphone or headphone connector is pushed in all the way.
â Make sure the volume is adjusted properly. A volume limit might be set. See “Setting
a Volume Limit” on page 25.
â iPod shuffle might be paused. Try clicking the Center button on the earphone remote
Feb 07, 2010 | Apple iPod shuffle MP3 Player
Soon as USB is connected to computer - It freezes up and will not repond until the ipod is reset, using menu and center button. Freezes up also, when IPOD Power Adapter is connected for charging battery....
check your usb drivers are upto date
using the latest usb driver. its your pc that is at fault
not the ipod try connecting to another pc.
Ray
Oct 01, 2009 | Apple iPod touch
My ipod nano is stuck on language selection and is frozen can you help me?
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
    Hope i helped you.
Thanks.
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
IPod hang
Dec 20, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod shuffle wont play music
It won't play music while connected to computer, that's for sure. It only plays when it's disconnected from the wall charger and computer.
The songs could be in the wrong format
AAC is iTunes native format
Mp3 generally works
WMA is iffy - only unprotected (non-DRM) files will work
Streaming songs won't work
-Tha Mp3 Doctor
Aug 29, 2008 | Apple iPod shuffle Second Gen. Silver (1...
My ipod was hang!
To reset your iPod:
Jul 17, 2008 | Apple iPod nano
Apple Ipod model A1136
just throw d ipod to wall...it will works very well....
Apr 12, 2008 | Apple iPod MA446LL/A MP3 Player
Problem downloading videos on ipod model no. A1137 EMC no. 2066
which ear-phones,datacable & usb charger can be used for apple i-pod (model no.A1137)EMC NO. 2066
Jan 06, 2008 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
4,299 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
