SOURCE: moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
SOURCE: Kohler 30 year old single handle shower valve - cold water only
Is this a dual handle or single handle? if it is a single handle
turn the valve 180 degree. if not, then check the cold water supply line.
SOURCE: waters hot instead of cold when you turn it on
You have to remove cartridge and rotate 180 degrees then re-install. Was it removed or replace lately?
Testimonial: " Thank you...The plumber put it in wrong.."
SOURCE: no cold water from Moen 2253 tub/shower valve,
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
