Question about Oster 5838 ExpressBake Bread Maker
Bread machine blows fuse
The fuse trips as soon as the bread maker starts the baking cycle. I have tried different outlets and it still happens. What can I do?
Posted by Nancy Barchus on
L Heme
    Master:
  • 395 Answers
The heating element is drawing too much current. Needs replacement.
Posted on Mar 06, 2015
Are there more recipes for my Crofton bread maker. I'm afraid that I haven't had a lot of good success with it recently. I have used Wrights complete bread mixes, they always dip in the middle
Hello, Julz -
Instead of looking for more recipes for your Crofton bread maker, or any other bread maker, I looked for information as to why the bread made with a bread maker would collapse on top.
The answers I found on this online baking formum:
http://www.thefreshloaf.com/node/9725/bread-machine-loaf-collapse-when-baking-starts
may prove instructive.
To summarize, some of the causes and remedies for bread maker bread collapsing on top:
- You may reside at a high altitude and have not adjusted the recipe so that it does not over-proof [over-rise]. Cut down on the yeast, sugar, and salt.
- Even if you are not at a high altitude, try a recipe with reduced amounts of yeast, sugar, and salt (try reducing the amounts by 1/4 to 1/3)
- Use the dough mix cycle; Then turn the machine off and let the dough rise a little less than the recipe calls for; When you see the dough has risen turn the machine on to bake.
- If your bread maker allows,.reduce the amount of time between rise and bake
If you want additional bread maker recipes, you will find more here:
http://allrecipes.com/recipes/338/bread/bread-machine/
I did find a PDF document (Adobe Reader software - free) for a model of a Crofton Breadmaker, model MD 8505. In case you do not have a manual for your machine. The manual I found has information on how to make adjustments for altitude (page 22) and other adjustments to make (pages 23 - 24), including what may cause the loaf to fall while baking. This is the link to the manual:
Best wishes.
Feb 06, 2018 | The Kitchen Appliances - Others
My bread appears to be rising well with a nicely rounded top then somewhere early in the bake cycle the top collapses or falls. What would cause that?
This is probably caused by a large bubble forming in the dome. Try cutting back on the yeast by a half teaspoon. Bread maker recipes are a hit or miss situation.
Jan 27, 2015 | Kitchen Appliances - Others
Everything works fine, bread rises and looks like it will be beautiful, but almost every time, the top collapses by the end of the baking cycle. This happens whether I use the regular cycle or the whole...
The next time you bake bread use 1 tablespoon less liquid. If it still collapses then the 2nd time use one tablespoon less liquid and ONE MORE tablespoon of flour. That should do it!
Dec 06, 2010 | Sunbeam 5833 ExpressBake Bread Maker
My bread machine was unplugged with about 20 left in the bake cycle. How do I get it to go bake into the bake cycle. Display panel is unlit
If your machine has a "Bake" cycle then choos that cycle and push start and adjust the timer so it cooks the right length of time. Your manual should tell you how long the the last bake cycle takes and just push your timer until that time is set less the 20 minutes already baked.
Nov 05, 2010 | Oster 5834 ExpressBake Bread Maker
Ive got a Salton SB 846 bread machine,that i had plenty of breadbaking pleasure.Suddenly the machine trips the main power supply when it is switched on??I have checked each and every wire connection.Can it...
You may want to try plugging in your breadmaker somewhere else in your house that is in a different area and start a program. If you have a bake stage choose that because it will pull lots of power. For example instead of plugging it in a kitchen outlet take into your garage or bathroom and turn it on there. If you still are tripping fuses then the problem is with your bread maker. If it doesn't trip the fuse or main doing that then email then you probably have too many applicances pulling power in your kitchen line that the bread machine was on. Please rate this answer for me or give a testimonial so I can continue helping others.
Oct 21, 2010 | Salton Kitchen Appliances - Others
My Breville BB380 Breadmaker trips power switch when going baking
When was the last time that you used the bread machine? If it has been in storage for a period of time, it is likely that the element has absorbed moisture. As soon as it starts baking, the element goes into action, and because it's "leaking to earth" the machine will trip your circuit breaker.
I recommend taking the machine to your local Breville Service Centre (locate via http://www.breville.com.au/care_agentsearch.asp) as the machine is still quite repairable. If the Service Centre is unable to dry out your element though the elements are no longer repairable.
May 22, 2010 | Kitchen Appliances - Others
I put ingredients in, selected dough cycle, won't start
If there is power to the unit (try another outlet or if a GFCI make sure it's not tripped) then it's probably a bad control board. The joys of computerized appliances....
Mar 29, 2009 | Welbilt ABM3500 Bread Maker
Baked Loaf
Yes it does. This is just a minor problem. All bread machines have this happen. The only way around is to use the machine on the dough cycle and bake it in the oven.
Jun 21, 2008 | Toastmaster TBR20H Bread Maker
Oster 5838 ExpressBake Bread Maker Logo
519 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
