Toaster Ovens Logo
A
Anonymous Posted on Mar 06, 2015
My breville toaster pizza oven lights up but will not heat
L Heme
Level 3:
Master:
  • Master 395 Answers
  • Posted on Mar 06, 2015
L Heme
Master
Level 3:
Master:
Answers
395
Questions
0
Helped
57463
Points
1163
The main element has probably shorted out.
2answers
Breville toaster oven - beeping and Code E05
According to sources, breville toaster oven E05 LCD error is non-resettable issue. You should immediately turn off your toaster oven and remove the power plug. After doing so, call breville customer care. Hope it helps!
1helpful
The bottom heating elements on my breville toaster oven model BOV 800 XL stopped working. What to do?
You could have them replaced but will it be cost effective to do so? Maybe a new toaster would be better and cheaper.
Breville smart oven no heat or convection fan. LCD and controls working and can hear the oven clicking on.
The fan probably operated on the heat... I would tackle the THERMOSTATS, heat elements (at least 2) and/or fuse first.
My favorite supplier, appliancepartspros, struck out on Breville
(never-mind) I'll add a couple of credible ones at the bottom.
Sears parts is a good information source... but very pricey ($$$$) for the EXACT SAME PARTS you can get elsewhere...
If you can determine from your OWNERS papers which part you want to try first... get the operating parameters... and and check with a volt meter (ohms scale... power OFF)... for continuity on the FUSE, heaters & thermostat.
There is a possibility your control board (PCB) is at fault... it seems to be getting scarce... Turn it over and look for a burned/broken solder joint.
http://www.ereplacementparts.com/breville-bov800xl-smart-oven-parts-c-116052_116061_116092.html
In any case... get three prices...
In the event that PCB is the issue I do recommend LOOKING TO SEARS because of their parts support and warranty...
Good luck (finding the FUSE).
Breville BOV800XL Smart Oven Parts
Parts and Accessories
Sears Appliance Parts
3helpful
2answers
Breville bov800xl wont turn on. Reset option?.
If the screen turns on and looks like it's working but there is no heat, then the problem is the thermal fuse. It takes reassembly and a $5 replacement fuse. I replaced mine with one of the same specifications and it lasted a month. I replaced it again with one that trips at a 10 degrees higher setting and it's been good for a couple of years now.
What ever setting I use Toaster, Pizza etc the oven runs for 3 minutes and stops and in the read out window E 1 comes on the screen
Unplug the unit for at least 30 seconds. Plug in, set clock. When making pizza punch in the time you wish it to run, such as "7:30" then "start". Watch carefully the first time to see how much time it takes to cook to your liking.
Elements not heating
Buy a new toaster. Very cheap appliance.
I need an operating manual for the Breville convection toaster oven
Hi there.
You will be able to find Owner's Manual of Breville Convection Oven at http://www.breville.com.au
Regards.
Pizza is soggy
Not working properly accordiing to the manufacturer.  Not fixable.
Top Breville Toaster Ovens Experts
deton8 von Splosion
Ngoro
Are you a Breville Toaster Oven Expert? Answer questions, earn points and help others
