Question about Hifonics Car Audio & Video
Here's a few things you can do to find out what's wrong ,first make sure you have 12volt on your batt lead and your remote turn on and make sure you have good ground.Take an ohm meter or a 9volt battery and put across/momentary the voice coil on your good sub should read somewhere between 2-8 ohms,if using a battery speaker should pop.if ohms check out or speaker pops your good connect it to your amps output.Next make sure you have a signal to the amp,if you have multiple amps use the rca cable from amp that's working for testing purpose.if all that checks out you'll need to have your amp check by professional
Posted on Mar 06, 2015
SOURCE: no sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Posted on Jan 02, 2008
SOURCE: blown resistior in a hifonics brutus bxi 1606d
If you can point it to me in the schematic diagram I might be able to help you. But I suggest you bring it to a qualified audio electronic technician if you still value it. cheers!
Posted on Oct 17, 2008
SOURCE: what do i do when its telling me that its protected.
Over current protection turns on when the amp draws more current than normal. It turns on so it doesn't catch on fire. Your amp has a fault, most likely in the output stages. These power transistors consume the most current and if they blow short then that will cause it to go into protection. If it is under warranty take it back, if not have someone in your area try to repair it. What load were you running anyway?
Posted on Dec 20, 2009
SOURCE: how to bridge a amp brutus hifonics 1200 watt
use the first - and the last + should run at 2 ohm then
Posted on Mar 10, 2010
SOURCE: I hooked my Hifonics BXi 1610 Brutus series
wire the subs if thair dual 4 ohm . in parallel. red to red and black to black. giving it a 2ohm load. do the other sub the same. and conect it on the amp . turn your gain about 12oclock and db level less than 12oclock and your frequnecy around 80-100. and that should work
Posted on Mar 21, 2010
Aug 16, 2012 | Hifonics BRZ1700.1D Brutus Series 1700...
Feb 01, 2010 | Hifonics Brutus BX 1205D Car Audio...
Dec 04, 2009 | Hifonics Brutus BX12D4 Car Subwoofer
Oct 16, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Jun 06, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Apr 24, 2009 | Hifonics Brutus BX12D4 Car Subwoofer
Apr 16, 2008 | Hifonics Brutus BX 1605D Car Audio...
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
Oct 07, 2007 | Hifonics Brutus BX 1505D Car Audio...
164 people viewed this question
