Question about Refrigerators
My temp on the fridge keeps on rising to 19 degrees but freezer temp ok
Posted by lionelltinte on
Julie Clark
    Sergeant:
  • 266 Answers
Are you talking about 19 degrees Fahrenheit? The normal temperature for the refrigerator section should be 38?, and the freezer should be at 0?, both in Fahrenheit.
Posted on Mar 06, 2015
Freezer temp. keeps rising
try to turn off the freezer and adjust the temp. settings to a minimum.. Make it 20 minutes for your fridge to turn off before you turn it on. If the temp. keeps on rising, refer to your freezer manufacturer to repair the thermostat inside of it.
Aug 27, 2011 | Frigidaire Refrigerators
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 25, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
My temp on my fridge is rising. It is usually on
what the problem is the ports that go from freezer to frige are all iced up you just need to defrost a few hours
Mar 12, 2010 | Refrigerators
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Frigidedaire
The refrigirator side of my fridge has stopped cooling, the freezer still works but the alarm went off last night and flshed" power failure" on the lettered panel. I have it set at 33 degrees but it keeps rising it is now at 61, help!
Nov 17, 2007 | Frigidaire Refrigerators
Refrigerators Logo
102 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
