Question about Kyocera FS-3900DN Laser Printer
Kycoera FS-3900DN service code 7410-0013781
How to clear code and what is it?
    Top Expert:
  • Kyocera Master
  • 76,416 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Mar 06, 2015
Kyocera service code 7410:0013781
Drum unit non- installing error The drum unit is not installed or not installed properly. The drum PWB EEPROM does not communicate normally.
Mar 06, 2015 | Kyocera FS-3900DN Laser Printer
I have Kyocera FS-3900DN , it shows on the display error code (call service 6030:1022274) thanks
This problem is caused by a poor contact in the fuser connector terminals.
Check both sides of the connection (in the printer and fuser unit) In most cases we will find small pieces of paper inside printer connector causing poor contact between printer and fuser unit connector.
Hope i was of any help. If i was, please rate me.
Thank you.
PcSimples
Mar 14, 2011 | Kyocera FS-3900DN Laser Printer
Kyocera fs-3900dn showing 7410:0024216 error code what do I do
The 7410 is a drum installation error code. This is typically caused when the waste bin is replaced. Open the left door and push on the drum unit just above the waste bin, usualy a click will be heard when pushing it in. Then power cycle the printer. This should fix the error message.
Apr 15, 2010 | Kyocera FS-3900DN Laser Printer
My ecosys fs-3900dn printer gives this error 0150:0119695
It is a "mechanical error". The part after the colon is the number of pages printed. It's probably worthwhile taking the trays, toner and cartridge out and opening all the access doors and checking for something obvious before calling in an engineer.
Jul 19, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
did the error came on after replacing tonercartridge ?
open the door at the left and push on the drum till you hear click, problem should be solved afterwards.
Jul 23, 2008 | Kyocera FS-3900DN Laser Printer
Service code
This is a laser problem. The polygon motor probably got jammed usually it needs to be cleaned and oiled or the motor has ceased.
Mar 10, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FS-3900DN Laser Printer Logo
56 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
