Question about Pool & Spa
Re Installed a rebuilt pump and now the pump starts surging once I open up the flow to the max. Previously it did not.
Reason why removed for overhaul ws the capacitor did not work , so didn't start and on ispection had a loose impeller nut and 1st stage impeller had rubbed on the diffuser.
Posted by Adrian Burns on
Geoffrey White
  • 3,961 Answers
I think an air leak into the suction side, or with the new-found power of a tight impeller, the water level in the skimmer box is a bit low.
Check all joints, especially the rubber bellows which is usually on the suction side of the pump basket, and the seal on top of that basket.
Posted on Mar 06, 2015
I have a Black Max 2600 PSI pressure washer, model BM80913, that gives a surge of pressure, and then pressure drops off. Solution?
Pump needs to be rebuilt or replaced, some of those pumps have a replacement surge valve inside, some do not
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
Sep 27, 2017 | Psi Garden
02 deville getting air out of cooling system
Remove the cap from the surge tank. Set the heater control temp to max (A/C in any mode EXCEPT max). Start the engine and idle until lower radiator to pump hose is hot. Allow the engine to cool to ambient, and then check/fill the surge tank and replace cap.
Nov 19, 2016 | 2002 Cadillac Deville
I have what I consider a strange problem. I have blow back on my air intake from time to time. My car is a 1991 BMW 750iL 12 cylinder. The car has been in storage for about 5 years. Ran great before...
Valve stuck open from time to time
Lets keep in mind your talking a 1991
sitting for a few years or not.
Do a cylinder leak down test.
What was the reason the mechanic gave you ?
Aug 01, 2013 | BMW Cars & Trucks
Engine won't continue to run!
sound like an air leak, too much air coming in kills engine, try spraying like starting fluid by and seals, or do a compressed smoke test
Apr 28, 2013 | Cars & Trucks
I have a 1986 gts corrolla that will not run unless air flow meter is held open
Now if your old fuel pump was loosing pressure it tends to lean out Overheating your catalytic converter and melting it so exhaust gasses can't flow To test this is easy just remove the two bolts holding it on the engine pipe Start the engine if runs fine replace cat converter
Sep 15, 2012 | 1986 Toyota Corolla 2 Door
Just installed rebuilt engine for 2001 chevy 1500 LS v-8 and it is overheating. top hose is hot. repaced the water pump, thermostat, sensor, surge cap, cleaned surge tank. could there be an air lock...
yes it may be, but did you check the radiator for blockage? inside and out side, check to see if there is dirt on the fins. also check the cooling fan operation.
top hose get hot so that meant the thermostat is working ( it's opening ) try to bleed the cooling system again
Jun 03, 2010 | 2001 Chevrolet Silverado 1500
No Fuel??? Not starting.
You have fuel flow but the question now is are the injectors pulsing. Given the year of the truck my gut says your ECU, Engine Control Unit, has failed. Mitsubishi had issues with the capacitors in their early 90's cars, trucks SUVs. I have been thru this with two monteros and one 3000GT, very common. To check your injectors rent a set of NOID lites from Autozone our such. Remove an injector plug and itstall a noid light. Turn the engine over, if no flash, no pulse. Remove the ECU and carefully open it up. Look for the capacitors, there should be 3, look under the capacitors on the board; if there is a grease like substance, often time it has a green hew to it, then the capacitor(s) have failed. It may be possible to replace the capacitors or simply purchase a rebuilt ECU. Be ceratin the MD number matches on the new unit.
Please let me know your results and if this had assisted you.
Thanks, Tom
Apr 23, 2010 | 1991 Mitsubishi Mighty Max
Why engine oil pump not function after engine overhauling?
PROBABLY IT WAS NOT REBUILT OR PROPERLY INSTALLED.
Apr 15, 2010 | 2004 Toyota Land Cruiser
Had Polaris rebuilt last summer. Then wouldn't
Thank you for posting your question here on Fixya.com.
Have you cleaned or replaced the in-line filter found at the wall socket? How about the pressure valve found just after the wall socket...is it fully open, possibly allowing too much water to bypass the cleaner and return to the pool?
How about the main filter? If overall system flow is reduced because of a dirty main filter the booster pump would be 'boosting' lower than normal pressure so the net result at the cleaner is reduced as well. A cartridge filter is especially problematic here. It can look clean after rinsing it but after enough use the element needs to be replaced to restore original system flow.
Are there multiple return paths for water back to the pool that have valves? Can you throttle down a return to, say a spa for example, to force more water to the dedicated line for the cleaner?
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 18, 2010 | Polaris Pb4 - 60 Booster Pump
Fuel not flowing as it should. 86 Corolla
Check the fuel pump pressure using a fuel pump pressure guage. It would not necessarily be unheard of to have a new, but bad, fuel pump. No or low pressure, then take the pump back and get another one.
Aug 10, 2009 | Toyota Corolla Cars & Trucks
Pool & Spa Logo
51 people viewed this question
Top Pool & Spa Experts
Bill Jordan
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
