Question about Oster Blenders
When you order parts it goes by model number, from what I can see there are several different model #'s for the Oster Versa,
BLSTBV-RV0-000 and BLSTVB-000-000.
try here, type your model # in the search area at the top.
Oster Blender Parts
or here,
Oster blenders lids blenders jars caps at Goodman
or here, under parts & accessories
Oster Parts Accessories Oster
I haven't found any where in Australia to get them, you may just have to get them on line.
Posted on Mar 05, 2015
SOURCE: top part of base broke off
This just happened to me too, and I think I just fixed it. First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99). I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are. Remove the rubber skirt to reveal four screws that hold the motor in. They are way in there so you'll need a long screw driver. Remove the motor and unscrew the old coupling. Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck. I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks. If your blender is the same, remove the bottom nut, fan blade and two washers. This gave enough of a rod to grip to get the old coupling off. (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck! Hope that helps!
Posted on Jan 20, 2008
SOURCE: Locking the jar on the base Oster Fusion 600W Blender
Here is the user manual for the Oster Fusion:
http://www.osterfusion.com/Manuals/MANUALS/BRLY07-Z00-000_43_29190737.PDF
It looks like you line up the threads, place the base on, and twist to tighten.
-Tha Mp3 Doctor
Posted on Mar 21, 2009
SOURCE: Square drive pin for Osterizer blenders?
I simply slid a small screwdriver in through one of the holes under the base to prevent the fan from spinning and unscrewed the pin counterclockwise using some small channel lock pliers. No disassembly necessary.
Posted on Aug 17, 2009
SOURCE: Fuse blew on my Oster BCVBO7 blender. Can it be
replace the fuse with the same specs. if it blows again, there is a short on the circuit.
Posted on Aug 30, 2009
SOURCE: My oster blender make a couple whirls, something
hello mam
this can be repaired please take it to a service center.
Posted on Sep 14, 2009
Testimonial: "Thank you. "
