The product now vibrates at a much lower level. This happened suddenly and has not changed. I bought it in September with a year warranty but is there anything i can do to fix it?
SOURCE: Dark Picture
The procedure for correcting dark picture is EXTREMELY dangerous.. If you're not sure about what you're doing call a qualified technician or you could seriously hurt yourself or get killed!
Picture Dark, abnormal, Changing Color Temperature
Make really sure before you sttart this process that the Tv has been unplugged for several hours and that you discharge the crt as you remove the anode. There is some extremely high voltage present for hours after the Tv has been off...
Or get a reputable shop to come out and do the procedure for you - - might just save picking yourself up of the opposite wall.
Bill
SOURCE: Sounds like its working, but nothing happens
I had the same problem with mine, it's due to the fact that the smaller spring has become un-lodged from the ******** itself.
You will need:
1. Roll of electrical tape.
2. Utility Knife
3. A small slot head screw driver OR a pair of needle nose pliers.
The solution is to unscrew the silver ring so that is can be moved up
and down. Now, you need to use a utility knife and cut the blue rubber
off of the spring. Once you have the blue rubber but off you can see a
large spring with another smaller spring inside. Push the head of the
******** till the larger spring's coils are an 1/8 to 1/4 of an inch
apart. Next take either the small slot head screw driver or a pair of
needle nose and jam the smaller spring back into the hole in the center
of the white plastic piece inside of the larger ring. Next plug it in
to make sure the vibration is working, reattach the silver piece and
tape the larger spring with electric tape.
SOURCE: Hitachi 60SBX72B has picture beam convergence issue
Convergence has failed. Goto www.tvrepairkits.com to get the parts and instructions.
SOURCE: I fixed my hitachi magic
rotate the head/neck part, one of the sides is not aligned with the notches in the bace of the neck. rotate it to fit right then you should be able to fit it on easily
