It's a 2 year old machine. tried running a program and all of a sudden i spotted the drum not rolling. no loud noises, though there is the sound of the roller spinning "blank"
SOURCE: indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: wm12x drum stopped
It's probably the bearings. The drum have probably get so loose from the bearing, so the belt have snapped off.
SOURCE: Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
SOURCE: Trouble with Indesit WI 102 washing machine
I had trhe same problem and was going deaf!!! I know this is probably too late for your machine but it may be usefull to someone else with this model.
Originally thought the bearings had gone but had great trouble trying to source some through UK websites so decided to strip the machine. Did this by touch (no manual!) and eventually found that the bolts holding the bottom weight to the drum had all come loose (all 3!). Trying to access them to tighten was the biggest problem as the front of the machine is welded on.
Managed the above by removing the rubber door seal from the door only and tightening two of the bolts from inside the door. The third I managed to access from beneath the machine. All were tightened using 10mm socket on a bar with extension (curtain pole!) slid over the end.
During this process I had the machine on its side, removed the securing brackets, top weight + springs and wedged the drum from beneath and the side as much towards the rear of the machine as possible to aid access.
Good Luck!
