I think you need to reprogram the module, you deleted the horn chirp and light flash confirmation. he dealer can reprogram for you.
Customer Preference Items
NOTE: If using the WDS, select Module Configuration and Programming, then follow the screen prompts.
NOTE: Make sure module is listed as supporting customer preference items and supports the specific item to be configured in the Module Configuration Index in this section.
- Select Service Bay Functions on the diagnostic tool.
- Select the module that contains the customer preference item to be programmed. Refer to the Module Configuration Index in this section.
- Select Customer Preference Items on the diagnostic tool.
- Select Module Option Content.
- Select the item to be enabled or disabled.
- Enable or disable the item as necessary to reflect the customer preference.
Principles of Operation
Power Door Locks
The generic electronic module (GEM) controls the power door lock and keyless entry system. Lock and unlock operation is achieved through the use of internal relays in the GEM. The relays are all door lock, all door unlock and driver door unlock. The normal path of the relays is to ground.
Pressing the door lock control switch to lock or unlock sends a ground signal to the GEM. The same GEM pin is used for unlock and lock input. The unlock signal is a direct connection to ground. The lock signal is altered by an internal resistor in the door lock control switch. This varied resistance identifies lock or unlock command to the GEM.
The door locks can also be controlled by the door key cylinder switches. For the liftgate door lock switch, turning the key to lock or unlock sends a ground signal to the GEM. The GEM will then ground the all door lock or all door unlock relay supplying voltage to the actuators. Turning the driver door key cylinder to the lock position sends a ground signal to the GEM. The GEM will then ground the all door lock relay supplying voltage to the actuators. Turning the driver door key cylinder to unlock sends a ground signal to GEM. The GEM will ground the driver door unlock relay and supply voltage to only the driver door actuator. If a second unlock ground is received within three seconds of the first, the GEM will ground the all door unlock relay supplying voltage to the passenger door actuators (if 2-stage unlock is equipped).
Keyless Entry
The keyless entry remote transmitter sends a signal that is received by the GEM internal antenna. Depending on the signal received, the GEM module will ground the appropriate internal relay and lock all doors or unlock the driver door. If the unlock signal is received again within three seconds of the first unlock, the GEM will ground the internal all door unlock relay unlocking all doors. The lock and unlock relay output to the actuators is controlled by the GEM, the same as power door lock operation from the control switch.
If the signal received is for the panic button, the GEM will cycle ground to the park lamp relay coil and horn relay coil. The park lamps and horn will continue to cycle until the panic button is pressed again or the ignition switch is turned to the RUN position, or after the timer expires.
