Question about Apple iTunes
How to delete apps from itunes
How do I delete apps from my iTunes on my desktop
Michael Lei
    Master:
  • Apple Master
  • 498 Answers
There are lots of fast ways to remove apps from iTunes. You can remove apps from iTunes directly, or just delete app .ipa file. Certainly, some programs also support to delete app with simple clicks. You can follow below steps to know the details.
Remove Apps from iTunes via iTunes Library
In order to address the problem of how to remove apps from iTunes library, you can refer to the steps shown below to help you.
1. On your Mac computer, you need to run the latest version of iTunes.
2. In iTunes interface, you need to click on the menu of "Library" and then hit on the option of "Apps".
3. In the right part of the iTunes window, you will see all apps in iTunes. Thus, you can press Command-A or apply "Edit > Select All" option to control-click any app that you want to delete.
4. When you have selected the apps, you need to right-click on one of them and choose the tab of "Delete" to hit on. A panel will pop up to ask you to confirm the deletion. You need to click on "Delete App" option. Thus, the chosen apps will disappear from your iTunes.
how to delete apps from itunes - remove-apps-from-itunes-via-itunes-library-1-1ixu4dy0vqssawsyurxjhp4d-1-0.jpg This method is not hard to handle at all. You can try it to see whether it works properly for you. If you want to use other solutions to make it, you can continue to read the following part.
Remove Apps from iTunes via App Directory
It is also a good idea for you to remove apps from iTunes via the app directory of iTunes. You only need to follow the instructions shown below to realize your goal smoothly.
1. First, on your PC, you need to open File Explorer and then navigate to the iTunes media folder. The location of the folder can be located by running iTunes on PC and then click on "Edit> Preferences> Advanced" tab successively. You should know that the default directory of iTunes media folder on PC is D:\Documents\Music\iTunes\iTunes Media. If you can not find it via this directory, you can go to the "Advanced" tab to check out.
2. When you are in the folder of iTunes media, you need to continue to click on the folder of "Mobile Applications". Thus, you will see all iTunes apps in the screen.
3. Choose the .ipa file of the app that you need to remove from iTunes and then hit on "Delete" key on your PC keyboard to get this work done.
You are also able to delete the whole app directory of iTunes to remove all apps from iTunes on PC. This method to fix how to remove purchased apps from iTunes is quite simple. You can give it a go right now.
For more methods, you can check this guide. Fast Ways to Remove Apps from iTunes
Posted on May 14, 2019
soma berast
    New Friend:
  • 17 Answers
1 - When viewing the apps on your iDevice in iTunes, you can check and uncheck apps from the Sync Apps list to add or remove them from your iDevice when you sync next. If there are apps listed that you know you'll never return to, you'll notice that there is no way to delete them from this list.
how to delete apps from itunes - delete-apps-from-itunes-43svrqxrf5oj4k5lwwnp3neh-2-0.png 2 - A window will pop up, asking you if you are sure you want to delete the selected apps. If you are certain of your intentions, click the Delete Apps button.
3 - Next, to remove all files associated with the apps you selected for deletion, click Move to Trash on the next window.
Posted on May 02, 2015
5 Related Answers
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: itunes wont recognize my iphone
I see. maybe and this is more than sure ...this new update of the program doesn't have the drivers for the device ..or its an incomplete program ...or ..a trial ...if you can not do anything . just roll back to the old program ...and see if it works...if the problem persist try to look for a driver to install... I mean the phone driver but ...I believe its something strange cause it should have seen it like a storage device and at least work the charger
Posted on Jul 25, 2009
John Espanol
  • 153 Answers
SOURCE: the desktop icons have all become the itunes icon
This seems to be a known issue that has been experienced by other users. I recommend you try to uninstall the Itune that you installed in your computer. Try to check this website or forum that I found, this could be helpful for you.
http://discussions.apple.com/thread.jspa?threadID=2054232
Posted on Jan 12, 2010
John Doe
  • 192 Answers
SOURCE: cannot open itunes app. unknown error 50.
I would uninstall and re install itunes. If you follow these articles from start to finish and don't miss a step you should be fine. if that dose not - repost with what happened.
Windows Xp
Windows Vista , 7
Posted on Apr 18, 2010
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: Error 450 on itunes
The 450 download error seems to be caused by either of two setups.
  1. You are not allowed to download something because parental controls are in place or
  2. You are using a 'user' account and not the 'administrator' account that is needed to download from the Internet.
It is not a firewall issue.
Please do be considerate when leaving positive ratings and feedback today. Thanks to the help of itunes for this solution as well.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 27, 2010
Anonymous
  • 98 Answers
SOURCE: how do you fix iTunes with 127 error
read this..
http://www.eeye.com/html/Research/Advisories/AD20040502.html
Posted on Jul 28, 2010
How to delete candy crush from my iPad permanently
Touch the app and hold your finger down until all the apps start to jiggle. You will see a circled "x" in the upper left corner. Tap it to delete an app. When done press the Home button.
You cannot delete any pre-installed iOS app.
If there is No 'X' on any apps you have Downloaded... then check in Restrictions... Settings > General > Restrictions > Deleting Apps = Off / On
If the app is in iTunes, then you delete the app in iTunes (Select the App and Press Delete on your Keyboard). If you then sync with your iDevice, the app will also be deleted from your iDevice.
Dec 06, 2016 | Apple iPad Tablets & eReaders
Tip
Apps open then close or crash on ipod touch, iphone
Issue : apps open then close
- in itunes > upper right corner > Store >
- deautherize cpu
- close itunes - re-open itunes
-in itunes > upper right corner > Store >
- reautherize cpu
-delete apps off ipod
-delete apps off cpu
- go to itunes store
- download app
- sync app
- app opens
- issue resolved
on Apr 15, 2010 | Computers & Internet
When I try download apps to my ipad I put a password in and then nothing happens
Open Settings, tap General, then Usage. Check available storage. If it's less than 500 mb, consider removing stuff. The list at the top of this window identifies the culprits. If Music is big, consider deleting music (in the Music app) from the iPad... it'll remain available on your desktop iTunes (or on iCloud if you use iTunes Match). If you have huge apps that you don't play, get rid of them... (GTA, RealRacing, etc. are gigantic). If you keep videos or video podcasts on your iPad, stop it... just sync the ones you need.
Make iTunes your friend. Plug you iPad into your desktop device (if you're using one) and go through everything to see what you're syncing. Uncheck anything you don't use. You'll get space back.
Nov 26, 2013 | Apple iPad 2
Hey guys.. I got an iPhone 5 clone and want to reset Factory Settings but don't know how! please help asap! Moreover i want to know how to delete applications on it :)
You can restore iPhone to factory settings with iTunes. iTunes enables users to back up data to iTunes and restore iPhone to factory settings. Before you start restoring iPhone to factory settings, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone.
1. Plug iPhone into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPhone at the upper right corner of iTunes, and then the information of your iPhone will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPhone before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPhone. Then iTunes will start restoring your iPhone to factory settings.
hey-guys-got-iphone-5-clone-want-reset-oxaxc0rwhkhzilrwacqreyis-1-0.jpg 4. Click Restore again to confirm. Then iTunes erases your iPhone and installs the latest iOS or iPod software. After you restore your iPhone to factory settings, it will restart. Now you can set it up as new.
hey-guys-got-iphone-5-clone-want-reset-oxaxc0rwhkhzilrwacqreyis-1-2.jpg For more methods to restore iPhone to factory settings, please feel free to read this guide. http://www.leawo.org/tutorial/how-do-i-restore-my-iphone-to-factory-settings.html
Apr 14, 2013 | Cell Phones
I recently updated my ibooks app for the iPhone 3 and now it will not open. Any suggestions?
This is a common bug when Apple upgraded the ibooks.
First, delete the app from your phone. Second, open itunes on your computer without the phone attached third, update all apps fourth, plug in your iphone and sync ibooks
if the above doesn't work then re-download ibooks from itunes
if both above dont work then you need to erase the ibooks app from your phone and itunes and then download the app again.
good luck!
Feb 12, 2011 | Apple iBooks
How can I reinstall the itunes icon on my desktop? I updated itunes and the only place that I see itunes are in the control panel on the add and delete programs. There are three users on computer and the...
It seems that while installation you selected the option "only for the current user" instead of all users. now you have two options the first one is easy log-in through the user which has itunes on the desktop copy the shortcut and browse to c: documents and settings ,users browse the other users folder open desktop and paste the shortcut in that folder. If this works its easy for you or else you will have to uninstall the app and re-install it while keeping in mind selecting for all users during installation.
Aug 20, 2010 | Apple iTunes
I deleted itunes by accident .tried to download it but it won't come thru .it keeps saying that the library was opened with a new download.
Firstly are you sure you deleted the actual application? You may have just deleted a shortcut instead - on a PC, go to C:/Program Files/iTunes/ and see if there's a file in there called 'iTunes.exe'
If there is you can drag and drop it back onto your start menu or desktop to restore the shortcut.
Mac user check in the 'applications' folder or Spotlight iTunes and see what's still on your computer. if you see iTunes.app you're fine, just reveal the app in finder and drag onto the dock.
If the program is NOT there...
Try this link to download the latest version direct from apple.
Apple - iTunes - Download iTunes Now
alternative server
iTunes 9.0.1.8 - FREE Download iTunes - iTunes: Digital music ...
Install direct from the new download, and follow the instructions onscreen
If you're still experiencing problems, let us know!
Oct 28, 2009 | Apple iTunes
CD/dvd drivers missing or malfunctioning
Sounds like you have and Upper and Lower Filter issue in the registry.
Listed below is the link for the MS document on how to fix this: http://support.microsoft.com/kb/929461
IMPORTANT
I suspect you did not complete all the steps in the document. In the document you need to delete the upper and lower filters in the registry and DELETE the burning software you added, shut down and then reinstall the software. This is often difficult for users since they have no idea what app is causing the problem.
With iTunes, make sure you are using the latest version. Older versions caused this upper and lower filter issue among other burning apps.
In some extreme cases you must uninstall and reinstall ALL burning software on your PC. This is easy on an HP. Delete the SW from Programs and then use Recovery Manager C:\PC Help and Tools\ etc..,. to run Application Recovery. You can only install one app at a time. Shut down between each install and check if your drives show up in Device Manager and burn.
Following the process above (installing one app at a time) will allow you to find out which app you added is causing the problem.
All the HP apps on the PC work fine as the PC is tested for issues like this. Something was added that over-wrote the Upper and Lower filters, essentially corrupting them so your ODDs don't work or don't even show up in Device Manager.
Good luck
Apex44
Jan 19, 2009 | HP Hewlett Packard Pavilion A6200N PC...
Apple iTunes Logo
145 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Lee Hodgson
Lee Hodgson
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
