Amana ACF3355AS Gas Kitchen Range Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Amana gas range's oven door will not stay shut. It is not snug against the oven. Repair says I need new hinges. Are they easy to replace?
Anonymous
Level 2:
  • Expert 58 Answers
  • Posted on Jul 09, 2009
Anonymous
Expert
Level 2:
Answers
58
Questions
0
Helped
18876
Points
170
They're not too bad, you may need to take apart part of the door to remove the hinges, just remember where everything goes as you take it apart. bring the door to the first stop, then bring the hinge pin locks into place to secure the door hinge lock, then remove door, or just slide the door up. then replace the hinges as needed.
Installing lower oven door on GE profile gas oven`
Removing or Reseating Oven Door To remove most oven doors:
  1. Open door to the BROIL POSITION, where you feel hinge catch slightly.
  2. Place your hands on both sides of the door near the handle.
  3. Lift the door up and away from hinges.
  4. If the door does not readily lift off, there may be 2 phillips head screws on the inside of the door down near the hinges that are holding it on.
To replace the door:
  1. Place your hands on both sides of the door near the handle.
  2. Resting door against knee, line up door with hinges and slip into place.
For instructions specific to your model, check your Owner's Manual or Installation Instructions. Download a copy of your Owner's Manual and/or Installation Instructions
1helpful
Add tension to loose oven door amana gas model args7650ss
Hello. You will need to replace the door hinge assemblies. The part numbers are as follows:
Right hand hinge 31715202
Left hand hinge 31715201
I hope this helps you.
I need a wiring diagram or schematic for an Amana Model AGDS902E Gas Range
http://www.appliancepartspros.com/parts-for-amana-agds902e-p1131831n-e.html
They have some diagrams, offer manuals, parts, & how to videos
24/7 Customer Support
app-logo.png?d=0914142
365-day-returns.png Amana + RangeAmana Range AGDS902E / P1131831N E Parts
Amana Range AGDS902E / P1131831N E Repair Parts Start New Search
SHARE:
Chat with a Pro AGDS902E / P1131831N E Range-S/c S/i Ddraft Gas Search
Most Popular Parts for Amana AGDS902E / P1131831N E whirlpool-oven-igniter-786324-ap2934763_01_th.jpg Sale Oven Igniter (9) View Repair Video whirlpool-top-burner-igniter-y0316773-ap4283295_01_th.jpg Top Burner Igniter View Repair Video whirlpool-broil-pan-set-4396923-ap3837379_01_th.jpg Broil Pan Set View Repair Video whirlpool-bracket-3801f656-51-ap4395315_01_th.jpg Bracket (2) whirlpool-sensor-temperature-y0314907-ap4282440_01_th.jpg Sensor, Temperature View Repair Video whirlpool-module-w-bracket-32020101-ap4041505_01_th.jpg Module W/bracket (1) View Repair Video whirlpool-oven-door-hinge-r0706010-ap4251866_01_th.jpg Oven Door Hinge, Left Side
whirlpool-assy-hinge-right-r0706011-ap4252510_01_th.jpg Assy, Hinge Right Download Manuals for Amana AGDS902E / P1131831N E Range-S/c S/i Ddraft Gas - Owner's Manual How to Troubleshoot and Repair Amana AGDS902E / P1131831N E Real advice from real customers just like you
Do-It-Yourself Stories from Customers like You Stephen F. bought this part whirlpool-oven-igniter-786324-ap2934763_01_th.jpg sale
Whirlpool Oven Igniter View Repair Video Oven took long time to ignite and when it did it came on with noise Stephen F. • Star Junction, PA • June 20, 2014 My Repair & Advice I looked up oven igniter on line and watched video, very helpful, then called and a women was able Read More...
Was this review helpful to you? 2 People found this story helpful
Do-It-Yourself Rating
  • 1
  • 2
  • 3
  • 4
  • 5
Easy Difficult Repair Time Estimate
Less than 15 minutes Corey B. bought this part whirlpool-bracket-3801f656-51-ap4395315_01_th.jpg
Whirlpool Bracket Needed anti tip plate Corey B. • Portland, OR • November 03, 2014 My Repair & Advice By moving the stove, installing with a few screws and sliding it back into place.
Was this review helpful to you? Do-It-Yourself Rating
  • 1
  • 2
  • 3
  • 4
  • 5
30-60 minutes How-to Videos for Amana AGDS902E / P1131831N E How to Replace Oven Igniter
How to Replace Top Burner Igniter
How to Replace Broil Pan Set
How to Replace Sensor, Temperature
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
1helpful
Amana ACS3350AS gas range oven door is bent and will not close properly. need to replace oven door and hinges. how much will this cost?
With a hammer, carefully flatten the areas of the door on both sides where it is sprung outward. I then drove self tapping screws into the side panels of the door just above where the bulge formed.
This formed a bond between the outside panel of the door and the inside panel.
Oven door does not consistantly shut completely
There is alot of unit that I personally repaired for the same problem. I designed a quick fix for it without changes the hinges. It is a little bit technical. The door has to be to took apart and in will need three washers on both sides of the hinge. this will be a $1.00 do it yourself fix if you dont have any coverage.nyc appliance repair can fix it for you.
1helpful
Hinge, oven door #822144
Pull up on the door to remove it from the hinges.
Remove the pan drawer on the bottom. Remove the spring from the hinge to be replaced. Remove the hinge mounting screws. Remove the hinge.
Reverse this process to install the new hinge.
14helpful
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
2answers
My Amana oven door will not shut tightly.
twist a tesher like a roll and put it betwing the door and the frame of stove then close the door gently to bring back the hinges to position.
Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
Top Amana Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
