UPM Indoor Electronic Programmable Plug-In Timer with Top LCD  Logo
D
Don Uhrich Posted on Mar 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The lights come on when they are supposed to but will not turn off at the time I thought I had set. Can you help? Also the 1 page manual is not very user friendly
ka4iup
Level 3:
  • Master 4,062 Answers
  • Posted on Mar 04, 2015
ka4iup
Master
Level 3:
Answers
4062
Questions
0
Helped
1096783
Points
51404
I have set these timers, and while they are tedious to work with, they do function as promised. I downloaded the manual: http://waterheatertimer.org/pdf/SE11P-Manual.pdf
If you have the clock and days set properly, try programming again using the information on pages 6-8. Follow the instructions for each line and button push.
I have a Polti Vaporetto 100b Steam Cleaner
First read cautions on page 20 of user manual. Then see page 31 troubleshooting. This problem is discussed there.
POLTI Vaporetto SMART 100 B Instruction Manual (Page 20 of 92) ' ManualsLib
I have a Polti Gallery to 100b Steak Cleaner
Read cautions of page 20 before proceeding. Then read troubleshooting on page 31 of manual.
Hi I've just noticed that my 2014 Ford Fusion interior LED back seat light will not turn off when my car is off and in park. .Any thoughts?
If the rear light will not switch off when it is supposed to then you have a 2014 model which has a 3 year warranty. So take it back to dealer service to fix for you under your new car warranty.
Otherwise set all your interior lights to manual and to the off position and when you want cabin lighting turn them on as needed.
When is the DC16 red light supposed to change to green?
You can see the manual for the DC16 here: (
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc16_uk_manual_cb_120710%20pdf.pdf )
Following the troubleshooting manual on page 6, fully charging the battery takes about 3 hours, for a run time of 6 minutes, so I'm not sure where 10 minutes comes from. The battery ships partially charged and was supposed to have been charged 3+ hours before a first use to get a full cleaning span.
It's also noted that you can get red lights if the temperature is out of an optimal range, and if the filter is not seated properly, so these would be things to check as well.
On the general checking list - look at the contacts for the battery and for the charger, make sure nothing is bent or corroded. Corrosion can be generally treated with use of some fine sandpaper or steel wool - be sure to blow the area clear of any steel wool fibers if you go that route. A better electrical contact sometimes will allow charging to get above a threshold voltage that will let the 'I'm charged' light turn green.
Good Luck! :-)
How do you turn off and on the driving (passing/running) lights on 2004 Royal Star Midnight Venture?
If its a Yamaha why not call their customer service number with the model/year and ask?
Timing on a 1990 Wrangler with a 4.2 liter
4.2L 6-Cylinder
1. Set parking brake. Shift automatic transmission to Park or manual transmission to Neutral. With A/C off, start engine and attain normal operating temperature.
2. With ignition OFF, connect an ignition timing light and a calibrated, expanded-scale tachometer.
3. Disconnect 4 " and 10 " Hg (CEC System) vacuum switch assembly wire connector (located at top of valve cover). Disconnect and plug distributor vacuum advance hose.
4. Start engine, increase engine speed to 1600 RPM and check ignition timing. Adjust timing to specification listed on Emission Control Information label (if necessary). Tighten distributor hold-down clamp and recheck ignition timing.
5. Turn engine off and remove timing light and tachometer. Connect No. 1 spark plug lead, if disconnected. Unplug and connect distributor vacuum advance hose. Connect vacuum switch assembly wire connector.
NOTE: If timing light has an adjustable advance control feature, turn control to OFF position.
Timing is set per the emissions tag under hood.
2helpful
4answers
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
GE Sensor microwave JES1855 no inside light on when microwave co
You can download GE owner's manuals and installation
instructions
here.
It is supposed to be when it cooks. If not, it may be burned out.
If that's the case, one would have to remove the cover to get to it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Only 1 function works at a time on mco16
That actually sounds like correct operation in that you cannot use the timer while it's cooking.
Assuming yours is model number is MCO160S, you can download your owner's manual here if you don't have it.
Page 19 tells you how to replace the cooktop lights and the cavity light.
Slot Light
The disk slot comes on briefly when:
-You turn the power on
-You put a disk in or take one out
And it pulses when you have a new message on your Wii message board. It does not stay lit while the Wii is on.
Top UPM Hardware & Accessories Experts
David Spradling
David Spradling
Are you an UPM Hardware and Accessory Expert? Answer questions, earn points and help others
