Question about Health & Beauty
Charging plug seems to haue gone out of kilter. charger does not plug in. Scooter does not have any power when key turned on. Is this terminal? Under warranty so havng to call engineer who may not get
Charging plug seems to haue gone out of kilter. charger does not plug in. Scooter does not have any power when key turned on. Is this terminal? Under warranty so havng to call engineer who may not get here til next week. Just want some experiences about this
Posted by Judy O'Carroll on
ADRIAN
    Sergeant:
  • 313 Answers
If its under warranty I would leave for the engineer to have a look or you could loose your warranty claim.
Posted on Jun 17, 2015
5 Related Answers
Dan Hudson
  • 118 Answers
SOURCE: battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Posted on Nov 27, 2008
gewiz
Rob Hill
  • 1414 Answers
SOURCE: will not charge
then I would first chec kthe connections that the battery charger connects to, check the batteries on another scooter .
Regards
GeWiz
Posted on Oct 01, 2009
gewiz
Rob Hill
  • 1414 Answers
SOURCE: Travel Pro Scooter charging problem.
hi , sounds likek a charger problem but if you have tried another charger then check the charger plug connection where the charger plugs in,
Check the batteries are connected correctly.
Regards
GeWiz.
Posted on Jan 13, 2010
littleone121
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
Neil Wood
  • 177 Answers
SOURCE: just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
Posted on Jun 05, 2010
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
I am charging my scooter and it is beeping what do i do
Charge without the key on. Make sure your charger is applying power to the scooter. It may have a blown fuse or some other internal problem. If your batteries were totally discharged your charger will not recharge them. You'll have to charge them individually with an automotive style battery charger that is NOT an automatic charger. It may take 3 days continuous charging to recover enough charge before your scooter charger will continue to charge until the batteries are fully charged. If this doesn't work then the batteries will never take a charge nad need to be replaced.
Oct 15, 2014 | Health & Beauty
Scooter only moves a short distance, then stops?
If the scooter in question is a Pride Victory with on board charger ? ( you plug a mains lead into it ?) now what happens with this particular scooter as the charger starts to fail, it's not charging the battery correctly, if you have access to a multimeter DC setting , check the voltage from one of terminal of the battery to the other terminal of the opposite battery, now it should read at least 18 volts , 0 volts then you need to change from one terminal to the other and same for the other battery ,, now if it below 24v that's the problem because as soon as you put it under load the voltage drops to under the minimum working voltage for the controller , hope that makes sense so other-words you need to replace the on board charger , contact me and I show you a way to do this cheaply...
Regards
www.gewizrepairs.co.uk?fixya
May 31, 2013 | Pride Victory 4 Wheel Mid-Size Electric...
Battery charger indicating that batteries are fully charged, but battery meter on the scooter shows no power at all. also the lights, indicaters etc arent working, im presuming that is resulting from the...
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Mar 14, 2011 | Pride New Mobility Victory XL 4 Wheel...
Hi do you need to turn on key to charge up battery on a wheeltech mobility scooter i just purchased with no manual thanks
No, you don't need to turn on the key to charge. Just plug in the charger and turn on the charger if there is an on/off switch on it. The charger indicator and the scooter meter will read full when the scooter is fully charged. Hope this helps.
Mar 02, 2011 | Electric Mobility 4 Wheel Power Electric...
Scooter's horn works but the battery is not charging when plugged in.
hi, right first of all, check the charger, check the fuse located in the charger if fitted, best way to test it is to try it on another scooter.
Now if youre sure the charger is working ok look at the charger socket is it a loose fitting if so wiggle it about gently, does the charger accept it charging ? is there a charging light on the scooter ? if so does it change colour when inserted , if not bad charger or charger fitting ? now if you have a multimeter , remove the seat and the cover under that , mind how you do this as it easily to hurt your back, show now you can see the batteries , check the leads to the batteries, have they come loose, now using the meter put a prode on a red terminal and the other lead on the other battery black terminal, now change terminal if no reading until you get about 20 to 25 volts , now inserted the battery charger , has the voltage changed or watch as it will start to rise , give it 20 minutes or so and if nothing changed , it pointing at your charger as having a fault ,even if the batteries are no good it will see show some output, now if the voltage measured on the batteries is lower than 18 Volts depending on scooter it will never move but the horn will still work as that requires only 12V.
Please leave feedback if this helps
Regards
Jan 16, 2011 | Pride New Mobility Victory XL 4 Wheel...
How do I charge my scooter I have lost my instructions
Look in your manual if you lost it then, go to razor.com and request one. But the simple answer is to:
1. Turn off the scooter
2. Plug charger into wall outlet.
3. Find the hole on the side that matches the charger plug(not the wall outlet plug) .
4. Plug the charger into the scooter.
5. Wait until the charger turn off ( if the charger is a smart charger), typical charging time is 4-6hours.
*If not a smart charger you can calculate the charge time by using an online battery charging time calculator.
Jul 02, 2010 | Razor E100 Electric Scooter
Just bought my dad a second hand go go 3 wheel elite scooter
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
I have a pride cleberity x...when i plug in the batt. Charger..will not charge...checked all fuze's
Not always the batteries, the chargers are made like garbage, I've gone throught 3 on my power wheelchair. The wheelchair companies will charge you over $300 for new chargers, check EBAY and get one for under $76 they work great and have a warranty
May 10, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
73 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
