Panasonic KX-FL511 Plain Paper Laser Fax Logo
Question about Panasonic KX-FL511 Plain Paper Laser Fax
How do I delete stored faxes in a Panasonic KX-FL511 without printing them?
Would like to delete the stored pages/faxes off the maching without printing them. Ihave the manual and cannot locate the answer to this problem. It is a fax only machine set to auto answer. It was out of paper so the faxes didn't print. I no longer need the information so I want to save toner and paper and simply delete them.
2 Related Answers
Anonymous
  • 215 Answers
SOURCE: Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Posted on Apr 13, 2009
Anonymous
  • 3085 Answers
SOURCE: Fax Machine Panasonic KX-Fl511 a fax was sent
Unplug the power cord for 10 mins.
Posted on Jul 02, 2009
The manual indicates where you may need to reset the unit if the memory is full or even if you just want to clear it, page 89-90.
You may use code: [MENU] [*][8][0] [SET] or [START]
You may also call - 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready.
How do you program the panasonic kx-fl511 to print fax confirmations sent.
How can i remove call service6 problem on my
Problem with the Panasonic KX-FL511 Plain Paper Laser Fax
razors
How do you adjust paper feed on a panasonic kx-fl511fax/copier
One of two things is happening ok maybe three. If the machine thinks the size of the paper is not what u are using this could happen. Try:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL511%20Laser%20Fax%20Machine.pdf
For any adjustment you could make.
The second is the paper is getting picked up a little late. The machine knows it did not print the entire page and finishes the job. Try cleaning the pick op roller.
The third is the page being sent to you is to long. This would likely be from one location only. There machine could be slipping when scanning and "extending" the page it is trying to send.
Hope this helps
4helpful
Need user manual
You can download a manual here:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/model.KX-FL511
Panasonic KX FL511
Unplug the power cord for 10 seconds.
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mehandi Husain ...
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
