Question about Canon PIXMA iP4200 InkJet Photo Printer
Got the printer installed but paper won't feed from top or the bottom, please advise.
SOURCE: Printer paper feed for Canon iP4200
There are probably problems with the rollers or the gear sequence that drives them. This type of repair may be more costly than what the printer is worth!
Jerry G.
Posted on Apr 19, 2008
SOURCE: Canon Printer PIXMA MP500
Check in the printer driver properties window on the computer. It sounds like the Paper Source is set to "Auto Sheet Feeder". You need to change this setting to "Paper Feed Switch" so that you can select the paper source from the printer itself.
Posted on Jul 25, 2008
SOURCE: CANON PIXMA IP1300 - The printer feeds in more than one page
I just had the same problem, I cleaned the rolers manually with alcohor and is working ok now
Posted on Oct 08, 2008
SOURCE: Pixma iP4200
I was having the exact same problem. Then I took the time to read the error messages I was getting and it said to press the paper load button on the front of the printer (the bottom one) to switch the feeder tray from bottom to top. hee hee. Too bad it took me 2 hours before I figured that one out! Hope this helps!
Posted on Apr 25, 2009
SOURCE: I am using the Canon
Hi, please get new driver here:
www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay pmyv
Posted on Feb 12, 2011
Does it try to take the paper?........
....yes......Dirty paper feed rollers, clean rubber rollers with slightly damp rag
....No....... Paper/tray not installed correctly or sticking / dirty paper out sensor
Sorry cant help further cant picture model in mind
