To [put it in layman terms, there is an electric motor that operates your gas pedal instead of your feet. There is something wrong with that mechanism, and the motor will no longer work. I would bet after 13 years on the road it will need a motor actuator, one of the rods connecting the cruise control motor to the throttle is rusted or jammed up. I would check it out mechanically for 5 mins before you get into more technical problems.
Basically : Flashing red light = broke
Green light = not broke
SOURCE: 1992 Honda Accord, cruise control will not engage
defective switch or an electrical short. please email me at [email protected] with anymore info you have
SOURCE: 2002 Honda Accord V6 check engine light on- local
po505 idle air control if this is the code all hondas do it eventully, small problem easy fix u have 2 choices either remove the idle air control motor and clean the inside of it u will find it's black and the spring inside is stuck clean it with carb cleaner or gum cutter any parts store will have this it's a dirty job it will work for awhile but to replace it is recommended its not expensive for a new one which u can get at any autoparts store autozone,advanced,napa etc. there is only 2 bolts in most cases maybe 3 i doubt it though if u go online t google and type in th eyear make and model and engine size in ur case it's a 3.0 v6 and look for idle air control locations u'll find it to do this job a shop will charge u anywhere from 100.00 for diag to retrive the code plus the part and the labor so about 250.00-375.00 it will only take u honestly maybe 15 minutes to perform only tools needed are a 10 millimeter wrench there is only 1 connector to disconnect and ur done if u do this u will still have the check engine light because u have not cleared it from the computer to do this just disconnect the negative battery terminal (the black one or has a neg sign - don't disconnect the positive side +)for 5 minutes then reconnect and the computer will have reset no more light. good luck it really is that easy
SOURCE: Want to replace fuse for cruise control on honda crv 2005
The cruise control suddenly stopped working and lites did not come on either, was working fine one day then next day it didnt'. Is there a fuse that might have gone out and if so where is it located?
SOURCE: 2005 Honda Accord 4cyl cruise control does not work
check all your fuses first then take a look at the brake switch and there is a criuse cancel switch also, i think there may be a problem with the switch,even if the cancel switch was bad i think the power would still stay on but cruise would just stop and power would stay on. check fuses and switches anyway to be sure then take a look at the power switch.
