I have a new compact flash card (4gig) and a new ata adapter.
They work fine on my computer. When I insert it into the Janome machine I get a window that pops up and says ''fat error'' and it asks if I want to format the card. I say YES and then it tells me it fails.
Any ideas???
Machine is a new memory craft 300e
You can just change your memory card only 1GB or less and upload designs through customizer software i think your problem will be solved.
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
SOURCE: Janome 300E Memory Craft reading .sew and .jef
Hi what you need to do is change the format as it is only able to process the one format.
What you can do is search online for software that converts the formay for you most of these sites are free so have a look you whould find plenty.
Alot of people have this problem but changing the format get round this ok let me know if you need further assistance ok
SOURCE: In embroidery mode I insert a card adapter into my
The solution was sooo easy.....one of my online embroidery groups suggested to put the card in my Janome and let the machine format it. It took about a minute and did not tell me what it was doing..and It worked! It put two folders on my card, Emb5 and ord#5, and I was to copy the jef files into the Emb5 folder, which I did and bingo! my Janome 9500 read the card and produced a screen with my jef files in it. I am a happy camper....I don't know if this works with all Janome machines but it did with mine.
Thanks for being here to help.
Pepsi lady
SOURCE: I have a Janome Memory Craft 9500. My problem is the memory card is acting up.
yes, but since you said the machine is 7 years old, & used extensively, then
I suggest to have to machine serviced if it has not been.
it could be a computer problem or mechanical problem
