Electronics - Others Logo
A
Anonymous Posted on Mar 04, 2015
I want to know if my Duracell 130 Watt AC/DC Power Adapter can be used to plug in a coffee maker into my cigarette lighter? I also misplaced the User Manual to this product. Can it be replaced. I believe the model is AC-6501. Can you help with this?
Randy Mitchell
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Mar 04, 2015
Randy Mitchell
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
3564
Points
42
It's not a good idea to run anything that needs a lot of wattage through a power converter using a 12v cigarette lighter plug. Coffee makers work by using a resistant heater element and it might work, but you could damage the coffee maker or the adapter by doing so.
Need DC car adapter for Duracell powersource mobile 100
the positive pin is the one to the right when looking at the power connector with the mobile 100 standing up correctly, the negative is the one at the far left. I made mine start charging this way: Still don't know what the middle pin is for. Just make your own cable out of an old car plug and possiblly a pc power source connector. it's not that difficult.
2answers
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
What is the brown wire and blue wire for the power cord on roadpro100w
I would guess the blue is POSITIVE, and goes to the tip of the lighter plug. However, get a voltmeter and check...
Cheers.
1helpful
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 • Vacuums
I have the ultraslim combo ac/dc charger. On the plane, using a standard plug through the power brick, there was no power to the laptop. I tried several different seats with the same result, while other...
The plane may have been running 400 Hz. power through the outlet, and your charger's input filter was blocking it so you didn't have enough voltage getting through. The other passengers probably did not have as much inductance (high-frequency filtering) in their stuff.
I have a Veco24B 400 Watt DC to AC inverter and the fuse that is suppose to be located in the cigarette lighter adapter is missing and I would like to know the size of fuse that is required.
I would put a 20 amp fuse in. The wiring for the cigarette lighter is usually around 15 - 20 Amps. The wiring also is not rated for more than 20A. I hope this helps. JOe
Son plugged ac/dc adapter into accessory plug and it sparked and afterwards cigarette lighter and accessory plug does not work anymore. Thinking maybe fuse but don't have manual to know where fuses are....
I always use a test light and check them all. Usly faster then looking up which fuse it is. Here is a diagram of fuse block anyhow. CIG stands for cigarette lighter.08b0868.png
DC Adapter for laptop doesn't work
there is nothing you can do appart from replace the car adaptor or check that the cigarette lighter is recieving power to the socket
regards
I just received the Garmin C340 GPS as a gift from my daughter.
Only use Garmin approved power connector either AC or DC (cigarette lighter adapter), otherwise you risk ruining your unit. The DC power adapter actually step down the voltage from 12vdc to 5vdc. Using anything other than a Garmin approved adapter can fried the unit.
Top Duracell Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Duracell Electronics - Other Expert? Answer questions, earn points and help others
