Cars & Trucks Logo
r
ray e stephens Posted on Mar 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Location fuel pump relay on a 1999 mitsubishi eclipse spyder cn
Richard Shindley
Level 2:
Sergeant:
  • Expert 216 Answers
  • Posted on Mar 04, 2015
Richard Shindley
Expert
Level 2:
Sergeant:
Answers
216
Questions
0
Helped
85987
Points
531
It is located in the fuel tank and is accessible from the truck.
Fuel pump Wire diagram for 02 Eclipse spyder
no engine told 2.4 or 3.0L?
the SM covers all that , the service manual..
2002
Mitsubishi Eclipse Spyder ! both pump and relay? same page in the book
buy one or rent it online, I DO all mine. paid.
best is test fuel pressure cranking dead engine or running,
PSI spec, factory tested. using real gauge (hand)
bad fuel filter , bad FPR< or bad pump, or not at all, barking up wrong tree most do. EFI logic confuses many.
https://eautorepair.net/Marketing/Default.asp
Where is the relay switch for the fuel pump in a 1999 Mitsubishi eclipse
relay switch is in the engine bay fuse box cannot remember of hand its location but there is only 2 or 3 relays in there.
1helpful
Where is the fuel pump relay and reset for a 1999 Mitsubishi eclipse spyder
The MPI relay is usually in the center console, behind the radio.
1helpful
Where is a Mitsubishi eclipse spyder 2003 wiper relay ?
The two relays for the front [main] wipers are part of the front ECU [engine computer] and are not serviceable separately. The front wipers are powered by a 10 amp [#22 in the relay box] battery hot fuse and a 20 amp [#18 in the junction box] & two 7.5 amp [#20 & #23 in the junction box] ignition hot fuses. The front ECU is located under the hood. It sits on top of the driver's inner fender well.
How to take off the fule pump on 2000 eclipse spyder
pull back seat and remove 4 screws on plate and pull cover unscrew cap and remove wires and hoses
Car will not start after it runs for awhile, starts fine cold and runs great 2002 eclipse spyder
sounds like my truck. some security code issue. gonna have to take it to the shop
Where is the 2 fuel pump relays located at on a 2002 eclipse gs spyder
I dont't know specifically per vehicle but most are position on the body/frame within a foot of the tank itself. Look up and image on line and then pop under your car and take a look.
2helpful
I need help findin the fuel pump relay in a 1995
the fuel pump relay is under the hood on the drives side if u look in the oners manual it will show u the excact location hope it helps
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
