get the screen to be checked by a tech, its a sign of loose signal cable which might burn the screen or short circuit the board and or other components as well !
it looks like you have no operating system is currupt for what ever reason was the F9 boot to install you backup operating system this may have been deletet you could reinstalled a new OS via cdrom the os . Your next option could be reinstall
If the WEBcam driver is not installed then download and install it. You can download the WEBcam and device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
When startup repair finishes even if it says it could not fix the problem try rebooting and select to run windows if it gives you that option.
Maybe you need to run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
