TEKA DHA888 double oven. We had a power outage and now the bottom oven does not work. Do I need to set the timer? If so how? as pushing the timer buttons does not have effect but the timer counts up the minutes if left alone?
Does the rest of the oven work ok? Did the timer work OK before the outage? Is the oven under warranty? Was the power outage at your home only? Check with the manual to see if it addresses your problem, there may be a way to reset the system and then I would say that you would need to contact Westinghouse and explain the situation.
I have a Teka HA830 oven I held the buttons down but it never resets. Would like to know if its possible to change the computer board, and where can i purchase it online?..
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
No, there is not a fuse on this model. You will need to repalce the clock assembly for this unit. Call us asap and we'll ship the correct part out to you asap so you can start cooking again. We look forward to working with you!
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
On the back of the motors there are safty overload reset's, these are small red push in buttons. Also there are fuses for each motor inside the control panels assembly.
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
