Question about Toshiba Computers & Internet
How to connect mouse to Toshiba laptop - Toshiba Computers & Internet
  • Toshiba Master
  • 4,062 Answers
First of all, I am assuming you are using a current laptop with USB connectors. For a corded mouse, insert the USB plug into a USB socket. After the computer recognizes the mouse, use the computer control panel software to set up the mouse. For a USB wireless mouse, insert the dongle into a USB socket. After the computer recognizes the dongle, use the computer control panel software to set up the mouse.
Posted on Mar 03, 2015
6ya staff
SOURCE:
Why wont my mouse install
To my understanding,the port for connecting the mouse to your laptop might be faulty.I would have said u should try installing a driver but most mouse dont need a driver to operate and also, since your laptop cannot detect a mouse at all, it most be the port for connecting the mouse that is faulty. I will advice you to take the laptop to an engineer for some checkings.
Aug 11, 2012 | Toshiba Computers & Internet
After not using my laptop for several months (it was plugged in however) my USB mouse will not work now when I boot up my Toshiba Satellite laptop.
Here are some trouble shooting steps you can try relatively easily....
If the mouse connects via a USB cable, try connecting it on another USB port while the laptop is on.
If it is an optical mouse, check to see if the LED(s) underneath are lit. Change ports until LED lights.
If you have another computer also with a USB mouse and it is working, try a mouse exchange. If the non-working mouse also does not work on the other computer and the mouse from the other computer works on your Toshiba Satellite laptop, the problem is likely with the non-working mouse.
Finally, If the non-working mouse is a wireless one, its battery may be dead. Try a new battery in it.
Feb 14, 2011 | Computers & Internet
My toshiba laser laptop mouse is broken right now. It is a mini retractable laser mouse. The laser is normally red but it is not turned on now.
that sounds like a bad cable connection from the electronics in the mouse to the main-board. That would most likely have to be repaired at Toshiba.
Oct 01, 2009 | Toshiba Computers & Internet
Connection procedure for Toshiba N745 mouse needed.
I don't know if this is the same as my mouse. However I have a satellite1955-S803 with wireless detachable keyboard and full sized optical wireless mouse. The original owner said it came with the laptop.
First I tried very hard to get the keyboard working. After a frustrating day of calling Toshiba, I noticed the "detachable" latches. I removed the keyboard to find a battery compartment. 4 days go by with me calling Toshiba trying to get a replacement. Finally found a battery at batteries plus that does work. about half the mAhr of the original but hey it works.
Now to the mouse. Replaced the AA's batteries but couldn't tie the mouse to the computer. I run linux so no M$ driver would help. Finally found a PDF of the manual and it says "if the mouse has trouble activating, press the wireless mouse button on the laptop."
That button is on the front left edge of the laptop (where the "Intel inside", "XP loaded", and "nvidia" stickers are located ) just to the left of the front silver "mode" button. Under the mouse press the connect button. (round near the optic laser but un-labled) then press the wireless mouse button on the computer and there you go. It just connects and works.
2 weeks I looked for this and it was just that simple.
Aug 26, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Please how do i get to activate a toshiba wireless mouse
just connect the transiever(the usb part) to the USB port.normally it will be recognized automatically. If not you shoul install the drivers. Dont forget to put batteries in the mouse. After that you should set up the connection between the transciever and the mouse. in most wireless mice there is a deep button under the mouse or hidden in the battery compartment you should push it and then push the button on the transciever( in some cases in the opposite order; first the transcievers button then the mouses button). usually an LED indicates that the connection have succeeded( either on the mouse or the transiever )
LEDs condition:
flashing on/off not connected.
continuous ON means connected.
Hope it helps
BR
/BS
Feb 18, 2009 | Toshiba Satellite A135-S4527 Notebook
Wireless mouse and usb game controller
It is faulty. Something internal is broken. I feel the only way to remedy this is replacement, sorry. I have seen this many times.
Oct 24, 2008 | Toshiba Satellite M45-S165 Notebook
Touch Pad Mouse not working unable to trouble shoot or properties for touch pad device to enable help please
Connect and external mouse, then go to Toshiba website and download the touchpad driver for your laptop and reinstall them again.
Oct 10, 2008 | Toshiba Tecra 9000 Notebook
Laptop Does not detect my USB OPTICAL MOUSE and USB keyboard
I have a hp laptop. My sis gave me a toshiba wireless optical mouse which I am unable to install as she lost the installation guide. Kindly help
Apr 10, 2008 | Toshiba Wireless Mouse PA3205U-1ETC
Computers & Internet Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
